Assembly guide
On this page, we will guide step by step on how to assemble this kit.
Step 1: Solder the resistors to the PCB.
Use a multimeter to differentiate resistor based on their resistance value. Start by putting the multimeter in resistance measuring mode and connect the multimeter's probes to the ends of the resistor, separate them based on the resistance value.
Solder the 330hm resitors
Solder the 330Ohm resistors to the bpc on pins marked R2-R8. Their orientation doesn't matter.
Find the resistors with markings as shown below:
Solder the 10kOhm resistors
Solder the 10kOhm resistors to the pcb on pins marked R1. Their orientation doesn't matter.
Step 2: Solder the LEDs
Solder the LEDs to the pcb on pins marked L1-L7
Step 3: Solder the SW-18020P Vibration sensor
Solder the SW-18020P on the pins marked S2
Step 4: Solder the switch
Solder the switch on pins marked S1, orientation doesn't matter.
Step 5: Solder the CR2032 battery holder
Rotate the pcb on its back side up and align the holder with drawn topology on pins marked BAT.
