Hardware details
Pinout
Pin details
| 3V3 | VDD | Power supply input (3.3 V). Provides operating voltage for the microphone. |
| DATA | DATA | Digital audio data output in PDM format. |
| CLK | CLK | Clock input for PDM interface. |
| SEL | SEL | Channel select pin: High = Left channel, Low = Right channel (for stereo). |
| GND | GND | Ground reference for power and signals. |
Dimensions
- Board Dimensions: 22 x 22 mm (0.9 x 0.9 inches)
- Header Pin Holes: 1.5 mm
- Soldered boards are LEGO compatible! 🧱
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
