Inputronic Keyboard - Reading key events
Connections for this example​
Connect the Inputronic Keyboard to your microcontroller via Qwiic/easyC cable or I²C pins as shown in the Getting Started guide.
Initialization​
To use the Inputronic Keyboard, first include the required library, create the keyboard object, and initialize it in the setup() function.
#include "SOLDERED-Inputronic-Keyboard.h"
InputronicKeyboard kbd;
void setup(){
if(kbd.begin()){
Serial.println("Keyboard initialized successfully!");
else{
Serial.println("Keyboard not found. Check connection.");
while(1);
kbd.begin()
Initializes the TCA8418 keypad controller, configuring the 8×10 matrix and I²C communication
Returns value: Boolean value. True if the keyboard was successfully initialized, False otherwise.
Reading Key Events​
The keyboard uses a 10-event FIFO to store key presses and releases. To read events, first check if any are available, then read and decode them.
void loop(){
while(kbd.eventsAvailable() > 0){
bool isRelease = false;
uint8_t row = 0, col = 0;
const char *label = nullptr;
if(kbd.readMappedEvent(isRelease, row, col, label)){
if(!isRelease && label){ // Only process key presses
Serial.print("Key pressed: ");
Serial.print(label);
Serial.print(" (Row: ");
Serial.print(row);
Serial.print(", Col: ");
Serial.print(col);
Serial.println(")");
delay(1);
Returns the number of pending events in the FIFO
Returns value: Integer value representing the number of events (0-15)
Reads one event from the FIFO and decodes it into row, column, and human-readable label
Returns value: Boolean value. True if an event was successfully read and decoded.
bool&isReleaseOutput: true if the event is a key release, false if press
uint8_t&rowOutput: matrix row (0-7)
uint8_t&colOutput: matrix column (0-9)
const char*&labelOutput: pointer to key label string (e.g., 'A', 'ENTER', 'SHIFT')
Converting Labels to Characters​
For printable keys, you can convert the label to a character. The library automatically handles SHIFT and CAPS behavior.
void loop(){
char ch;
if(kbd.labelToChar(label, ch, true)){ // true = apply SHIFT
Serial.print("Character: ");
Serial.println(ch);
delay(1);
kbd.labelToChar(label, ch, applyShift)
Converts a single-character label to a printable character. Automatically applies SHIFT and CAPS logic.
Returns value: Boolean value. True if the label is a printable character.
const char*labelInput: key label from keymap
char&chOutput: resulting character
boolapplyShiftWhether to apply SHIFT transformations (default: true)
Serial Monitor output
Serial Monitor output showing key events
Full Example​
KeyboardPoll
Polls the keyboard for key events and prints each key press with its label, row, and column to the Serial Monitor.
