Inputronic Keyboard - Live typing to Serial
Overview​
This example demonstrates live typing using the Inputronic Keyboard with output to the Serial Monitor. Characters are printed in real-time as you type, making this ideal for terminal-style input and debugging.
Initialization​
Include the library, create the keyboard object, and initialize it. If the keyboard isn't found, the program halts.
#include <Arduino.h>
#include "SOLDERED-Inputronic-Keyboard.h"
InputronicKeyboard kbd;
void setup(){
if(!kbd.begin()){
Serial.println("Keyboard not found!");
while(1);
Serial.println("Start typing:");
Handling Special Keys​
Inside the main loop, after reading each key event with readMappedEvent(), special keys are handled by comparing the label string. Release events and modifier-only keys (CAPS, SHIFT) are skipped.
if(!strcmp(label, "SPACE")){
Serial.print(' ');
continue;
if(!strcmp(label, "BACK")){
Serial.print("\b \b");
continue;
if(!strcmp(label, "ENTER")){
Serial.println();
continue;
// CAPS and SHIFT are modifiers only
if(!strcmp(label, "CAPS") || !strcmp(label, "SHIFT"))
continue;
Key Behavior​
KeyAction
Printable keysPrinted to Serial
SPACEPrints space character
BACKTerminal-style backspace (\b \b)
ENTERPrints newline
CAPSToggles upper/lower keymap (internal)
SHIFTModifier (handled automatically)
Printing Characters​
For all remaining keys, labelToChar() converts the label to a printable character with SHIFT applied automatically, and prints it to the Serial Monitor.
char ch;
if(kbd.labelToChar(label, ch, true)){
Serial.print(ch);
kbd.labelToChar(label, ch, applyShift)
Converts a single-character label to a printable character. Automatically applies SHIFT and CAPS logic.
Returns value: Boolean value. True if the label is a printable character.
const char*labelInput: key label from keymap
char&chOutput: resulting character
boolapplyShiftWhether to apply SHIFT transformations (default: true)
SHIFT and CAPS logic is handled internally by the library. When SHIFT is held:
  • Letters have their case inverted (CAPS XOR SHIFT)
  • Numbers and symbols use the shift map (e.g., '1' becomes '!')
Serial Monitor live typing
Live typing output in Serial Monitor
Full Example​
SerialType
Demonstrates live typing with the Inputronic Keyboard, printing characters to the Serial Monitor in real-time with support for SPACE, BACK, ENTER, SHIFT, and CAPS keys.
