MakerICE Adapter SAM - Overview
The MakerICE Adapter SAM is a breakout adapter for the Atmel-ICE programmer. This breakout enables a fast and reliable connection to any SAM microcontroller with its pin positioning. With direct signal routing for SWDIO, CLK, SWO, nRST, VGT and GND this adapter ensures reliable communication between your Atmel ICE and any SWD-capable target.
It's ideal for engineers, educators and advanced makers working with SAM devices, the board provides a stable interface for development and testing.
333215
Key Features
  • SWD Only: Supports Serial Wire Debug programming and debugging
  • 6-PIn SWD Header: Standard pinout(VTG, nRST, SWDIO, CLK, SWO, GND)
  • 10-Pin IDC Input: Connects directly to the Atmel ICE ARM port
  • Broad SAM support: Works with all SAM devices that use SWD
  • Direct Connection: No extra components or configuration required
  • Compact Design: Saves bench space and reduces wiring complexity
  • Dimensions: 38 x 22 mm (1.5 x 0.8 inch)
