7.6 Morse Code Transmitter
The goal of this project is to create a Morse code transmitter using the NULA MINI and a single LED.
When you type a message in the Serial Monitor, the board converts it into Morse code and blinks the LED to represent dots and dashes.
This example demonstrates timing control, text processing, and LED output — combining them into a fun and educational light communication project.
- How to convert text into Morse code patterns.
- How to use
Serial.readStringUntil()to receive user input. - How to blink a LED using timed delays for dots and dashes.
- How to control message pacing using letter and word gaps.
Hardware required
- 1× Soldered NULA MINI board
- 1× LED
- 1× 330 Ω resistor
- Breadboard
- Jumper wires
- USB-C cable
How it works
Each letter or number in Morse code is made of a sequence of short and long light pulses:
- Dot (·) = short blink (300 ms)
- Dash (–) = long blink (900 ms)
- Pause between symbols = 300 ms
- Pause between letters = 900 ms
- Pause between words = 2100 ms
When you type a message in the Serial Monitor (for example, SOS), the NULA MINI:
- Looks up the Morse equivalent (
... --- ...). - Blinks the LED accordingly using
delay()to time each pulse. - Waits between letters and words automatically.
This simulates how early telegraph systems transmitted coded messages over light or radio.
Wiring and connections
| Component | NULA MINI Pin | Description |
| LED anode (long leg) | IO2 | Digital output for Morse signal |
| LED cathode (short leg) | → 220 Ω resistor → GND | Current-limiting resistor path |
| Common ground | GND | Shared system ground |
Full code
Below is the full example code for this project:
#define LED_PIN 2 // LED output pin
int DOT_DURATION = 300; // base time unit (ms)
int DASH_DURATION = DOT_DURATION * 3;
int SYMBOL_GAP = DOT_DURATION; // gap between dots/dashes
int LETTER_GAP = DOT_DURATION * 3; // gap between letters
int WORD_GAP = DOT_DURATION * 7; // gap between words
struct MorseEntry { char letter; const char *code; };
const MorseEntry morseTable[] = {
{'A', ".-"}, {'B', "-..."}, {'C', "-.-."}, {'D', "-.."}, {'E', "."},
{'F', "..-."}, {'G', "--."}, {'H', "...."}, {'I', ".."}, {'J', ".---"},
{'K', "-.-"}, {'L', ".-.."}, {'M', "--"}, {'N', "-."}, {'O', "---"},
{'P', ".--."}, {'Q', "--.-"}, {'R', ".-."}, {'S', "..."}, {'T', "-"},
{'U', "..-"}, {'V', "...-"}, {'W', ".--"}, {'X', "-..-"}, {'Y', "-.--"},
{'Z', "--.."},
{'1', ".----"},{'2', "..---"},{'3', "...--"},{'4', "....-"},{'5', "....."},
{'6', "-...."},{'7', "--..."},{'8', "---.."},{'9', "----."},{'0', "-----"},
const int MORSE_COUNT = sizeof(morseTable) / sizeof(MorseEntry);
// Lookup function
const char* getMorseCode(char c) {
c = toupper(c);
for (int i = 0; i < MORSE_COUNT; i++)
if (morseTable[i].letter == c) return morseTable[i].code;
return "";
void blinkSymbol(char symbol) {
int duration;
if(symbol=='.'){
duration=DOT_DURATION;
else{
duration=DASH_DURATION;
digitalWrite(LED_PIN, HIGH);
delay(duration);
digitalWrite(LED_PIN, LOW);
delay(SYMBOL_GAP);
void transmitText(const String &text) {
Serial.println("\n--- TRANSMITTING ---");
Serial.print("Text: "); Serial.println(text);
Serial.print("Morse: ");
// Display Morse translation in serial
for (unsigned int i = 0; i < text.length(); i++) {
const char *code = getMorseCode(text[i]);
Serial.print(code);
Serial.print(" ");
Serial.println("\n--------------------");
// Blink Morse code on LED
if (*code == ' ') {
delay(WORD_GAP);
continue;
for (int j = 0; code[j]; j++){
blinkSymbol(code[j]);
delay(LETTER_GAP);
Serial.println("\nTransmission complete!\n");
pinMode(LED_PIN, OUTPUT);
Serial.println("Enter text to send via Morse code:");
if (Serial.available()) {
String input = Serial.readStringUntil('\n');
input.trim();
if (input.length() > 0) transmitText(input);
7.6_Morse_Code_Transmitter.ino
Project that converts text entered in the Serial Monitor into Morse code blinks using a single LED on the NULA MINI board.
