6.3 Sending Data
The goal of this example is to show you how to send data from your NULA MINI board to a web server over Wi-Fi using the HTTP POST method.
You will use a free service called webhook.site, which allows you to instantly see the data sent by your device.
- How to connect the NULA MINI to your Wi-Fi network.
- How to send a POST request to a web server using the HTTPClient library.
- How to format and send data from your board.
- How to monitor incoming data using webhook.site.
Hardware required
- 1× Soldered NULA MINI board
- 1× USB-C cable
- Wi-Fi network with internet access
How it works
This example connects the NULA MINI to your Wi-Fi network and sends a random number to a remote server every 5 seconds using the HTTP POST method.
Each POST request includes a field called number, containing a value between 0 and 100.
On webhook.site, you’ll see these requests appear in real-time along with all the data sent.
Setting up webhook.site
- Go to webhook.site.
- Copy the unique URL shown at the top of the page, it is in the following format:
https://webhook.site/your-unique-id - Replace the value of the
webhookURLvariable in your code:
const *char webhookURL = "https://webhook.site/your-unique-id";
POST request
While a GET request is used to retrieve information from a server, a POST request is used to send data (sensor readings, form inputs, device statuses...).
Code
Below is the complete code for this example:
#include <WiFi.h>
#include <HTTPClient.h>
const char* ssid = "Your_SSID";
const char* password = "Your_PASSWORD";
// Replace with your unique webhook.site URL
const char* webhookURL = "https://webhook.site/your-unique-id";
const unsigned long POST_INTERVAL = 5000; // 5 seconds
unsigned long lastPost = 0;
Serial.println("Wi-Fi POST Request Example");
WiFi.begin(ssid, password);
Serial.print("Connecting to Wi-Fi");
delay(500);
Serial.print(".");
Serial.println();
Serial.println("Connected to Wi-Fi!");
Serial.print("IP Address: ");
unsigned long now = millis();
if (now - lastPost >= POST_INTERVAL) {
lastPost = now;
if (WiFi.status() == WL_CONNECTED) {
HTTPClient http;
// Generate random number (0–100)
int randomNumber = random(0, 101);
String postData = "number=" + String(randomNumber);
Serial.println("----------------------------------");
Serial.println("Sending POST request to webhook.site...");
Serial.print("Data: ");
Serial.println(postData);
http.begin(webhookURL);
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
int httpResponseCode = http.POST(postData);
if (httpResponseCode > 0) {
Serial.print("Server response code: ");
Serial.println(httpResponseCode);
String response = http.getString();
Serial.println("Response body:");
Serial.println(response);
} else {
Serial.print("POST failed. Error: ");
Serial.println(http.errorToString(httpResponseCode));
http.end();
} else {
Serial.println("Wi-Fi not connected. Reconnecting...");
6.3_Sending_Data.ino
Example that shows how to send data from the NULA MINI to webhook.site using an HTTP POST request.
