7.6. Morse Code
A project that uses an LED and a buzzer to transmit user-input messages in Morse code. User can enter a message through the serial monitor, each character is then encoded and signaled accordingly.
- How to read text from serial input
- How to encode text characters using Morse code
Parts required:
- Soldered NULA Mini Board
- Breadboard
- 1 x LED
- 1 x Buzzer
- 1 x 330Ω Resistor
- Some jumper wires
- Place the buzzer on the breadboard, connect the positive pin on GPIO 4, and other pin to GND.
- Place the LED so that each leg is in a different row, connect the positive (longer) leg to GPIO 4, and negative (shorter) leg to GND using a resistor.
Code Example
Import necessary libraries.
from machine import Pin, PWM
Define pins used for an LED and a buzzer.
LED_PIN = 3
BUZZER_PIN = 4
This is how long the pause between signals will be.
# Unit time in seconds (dot length)
UNIT = 0.12
Initialize the Pin object for LED and PWM object for the buzzer. Set them off initially.
led = Pin(LED_PIN, Pin.OUT)
led.value(0)
buzz = PWM(Pin(BUZZER_PIN))
buzz.freq(800)
buzz.duty(0)
Functions for playing/muting buzzer.
def buzzer_on():
buzz.duty(512)
def buzzer_off():
buzz.duty(0)
Dictionary which maps characters to their Morse code strings.
# Morse code map (International)
MORSE = {
'A': '.-', 'B': '-...', 'C': '-.-.', 'D': '-..', 'E': '.',
'F': '..-.', 'G': '--.', 'H': '....', 'I': '..', 'J': '.---',
'K': '-.-', 'L': '.-..', 'M': '--', 'N': '-.', 'O': '---',
'P': '.--.', 'Q': '--.-', 'R': '.-.', 'S': '...', 'T': '-',
'U': '..-', 'V': '...-', 'W': '.--', 'X': '-..-', 'Y': '-.--',
'Z': '--..', '0': '-----', '1': '.----', '2': '..---', '3': '...--',
'4': '....-', '5': '.....', '6': '-....', '7': '--...', '8': '---..',
'9': '----.'
Morse signaling functions for 'dot' and 'dash'.
def dot():
led.value(1)
buzzer_on()
time.sleep(UNIT) # Dot = 1 unit
led.value(0)
buzzer_off()
time.sleep(UNIT)
def dash():
led.value(1)
buzzer_on()
time.sleep(UNIT * 3) # dash = 3 units
led.value(0)
buzzer_off()
time.sleep(UNIT)
Function that sends a single character in Morse code. After each character is signaled, wait 3 units before signaling next.
def send_character(morse_code):
for _, s in enumerate(morse_code):
if s == '.':
dot()
elif s == '-':
dash()
# After character, wait additional 2 units (since last dot/dash already waited 1)
time.sleep(UNIT * 2)
Function that takes user input from serial monitor as parameter and goes through each character. For every character found in the dictionary send a corresponding Morse code, if the character is not in the dictionary, pause briefly and continue.
def send_text(msg):
msg = msg.strip()
for _, ch in enumerate(msg):
if ch == ' ':
# Word gap: 7 units total, previous character added 3 units
time.sleep(UNIT * 4) # send_character already added 3 units total (1 after last symbol + 2)
continue
code = MORSE.get(ch.upper())
if code:
send_character(code)
else:
Main loop that takes a user input from serial using input() method and transmits the message as Morse code.
# Main loop
print("Morse transmitter ready. Type a message and press Enter.")
try:
try:
line = input()
except Exception:
line = ''
if not line:
continue
print("Sending:", line)
send_text(line)
print("Done.")
except KeyboardInterrupt:
print("Stopped by user")
finally:
led.value(0)
buzzer_off()
