2.3. Photoresistor Analog Read
Along with reading digital inputs, we can also measure analog values using the built-in ADC (Analog-to-Digital Converter) on the NULA Mini board. While digital inputs can only detect two states (HIGH or LOW), analog inputs represent a continuous range of values. In this example we'll use a photoresistor (LDR) to measure the intensity of light which then changes its resistance. NULA Mini by default converts the voltage (ranging from 0V to 3.3V) into a number between 0 - 4095 (12-bit ADC).
- How to use a photoresistor
- How to read analog values
Parts required:
- Soldered NULA Mini Board
- Breadboard
- 1 x Photoresistor
- 1 x 10kΩ resistor
- Some jumper wires
- Place each leg of the photoresistor in a different row on the breadboard
- Connect one leg to 3.3V and the other end to the ADC capable pin on your board (IO5). From that same row then connect 10kΩ resistor between IO5 and GND.
Code Example
Along with Pin module we import the ADC which allows us to create the object of that type which will be used to read analog values from a pin.
from machine import Pin, ADC
Define pin used for LDR sensor and create an ADC object for that pin.
LDR_PIN = 5
ldr = ADC(Pin(LDR_PIN))
Main loop which reads the analog value from that pin and prints it over to serial.
# Read the analog value from the photoresistor
ldr_value = ldr.read()
# Print the LDR value to the console
print(f"LDR Value: {ldr_value}")
# Pause the program briefly to allow some time for CPU
time.sleep(0.5)
