5.1. Temperature and Humidity
Using the SHTC3 Temperature and Humidity sensor we can accurately measure temperature and humidity values. This example uses SHTC3 sensor with its MicroPython module to measure data and print it out.
- How to connect SHTC3 sensor to NULA Mini board using Qwiic cable
- How to connect SHTC3 sensor to NULA Mini board using native version
- How to read sensor values and display them
Parts required:
- Soldered NULA Mini Board
- SHTC3 Temperature and Humidity sensor
- 1 x Qwiic cable
Required components
- If you are using the Qwiic just plug one end in the NULA Mini board and one in the SHTC3
- If you are not using the Qwiic connector, manually connect your board using the table below:
| NULA Mini | SHTC3 |
| VCC | VCC |
| GND | GND |
| SDA | IO3 |
| SCL | IO4 |
Code Example
Import necessary machine modules and SHTC3 module for sensor setup and initialization.
from machine import Pin, I2C
from SHTC3 import SHTC3
Setup I2C connection with the sensor using custom I2C pins and initialize the SHTC3 object.
i2c = I2C(0, scl=Pin(4), sda=Pin(3))
shtc3 = SHTC3(i2c)
If you are using Qwiic connector initialize object in this way.
# Initialize sensor over Qwiic
# shtc3 = SHTC3()
Main loop that samples values before reading them and printing them out to console. The code samples values every 5 seconds.
# Infinite loop
# Sample the values before reading them
shtc3.sample()
# Read the temperature and humidity values that were just sampled
temperature = shtc3.readTemperature()
humidity = shtc3.readHumidity()
# Print the values to the console
print(f"Temperature: {temperature:.1f}, Humidity: {humidity:.2f}%")
# Pause the program for five seconds
time.sleep(5.0)
