7.3. RGB LED Controller
Under construction
Project which uses Red, Green and Blue LED that light up depending on the resistance measured by photoresistor.
  • How to read analog value from photoresistor
  • How to control the LEDs displaying various colours
Parts required:
  • Soldered NULA Mini Board
  • Breadboard
  • 1 x Red, Green, Blue LED
  • 3 x 330Ω resistors
  • 1 x 10kΩ resistor
  • 1 x Photoresistor
  • Some jumper wires
Under construction
Required components
  • Place the buzzer on the breadboard, connect the positive pin on GPIO 19, and other pin to GND.
  • For each pushbutton, place it on the breadboard, connect one terminal of the button to the pin declared in code, and the other terminal to GND using jumper wires.
  • Connect the LCD using Qwiic cable
Under construction
Components connected together
Code Example
Import necessary modules.
from machine import Pin, ADC, PWM
Define pins for LEDs and photoresistor
LDR_PIN = 5       # Analog input pin for photoresistor
RED_PIN = 2 # PWM pin for red LED channel
GREEN_PIN = 3 # PWM pin for green LED channel
BLUE_PIN = 4 # PWM pin for blue LED channel
Declare ADC object for photoresistor and PWM objects for LEDs.
adc = ADC(Pin(LDR_PIN))
pwm_r = PWM(Pin(RED_PIN), freq=PWM_FREQ)
pwm_g = PWM(Pin(GREEN_PIN), freq=PWM_FREQ)
pwm_b = PWM(Pin(BLUE_PIN), freq=PWM_FREQ)
PWM_FREQ = 1000 # PWM frequency in Hz
Function to map value from one range to another.
def map_range(x, in_min, in_max, out_min, out_max):
if in_max == in_min:
return out_min
val = (x - in_min) * (out_max - out_min) // (in_max - in_min) + out_min
return max(min(val, max(out_min, out_max)), min(out_min, out_max))
Main loop that reads LDR value and lights up LEDs based on that value.
# Main loop
# Read LDR value
ldr_value = adc.read()
print("LDR value:", ldr_value)
# Map LDR value to RGB colors
if ldr_value <= 1365:
# Dark -> Red to Green
r = map_range(ldr_value, 0, 1365, 255, 0)
g = map_range(ldr_value, 0, 1365, 0, 255)
b = 0
elif ldr_value <= 2730:
# Medium light -> Green to Blue
r = 0
g = map_range(ldr_value, 1366, 2730, 255, 0)
b = map_range(ldr_value, 1366, 2730, 0, 255)
else:
# Bright -> Blue to White
r = map_range(ldr_value, 2731, 4095, 0, 255)
g = map_range(ldr_value, 2731, 4095, 0, 255)
b = 255
# Write PWM values to RGB pins
pwm_r.duty(int(r * 1023 / 255))
pwm_g.duty(int(g * 1023 / 255))
pwm_b.duty(int(b * 1023 / 255))
# Print RGB values
print("RGB:", r, g, b)
# Small delay
time.sleep_ms(100)
