7.2. LED Traffic Light
Under construction
In this project we will use 3 LEDs to simulate normal traffic light operation. Pushbutton is added to represent catwalk interrupt button which stops the normal operation of the traffic light to allow "pedestrians" to cross over.
  • How to use LEDs in a sequence
  • How to trigger a hardware based interrupt
  • How to attach a timer interrupt in TIMER.ONE_SHOT mode
Parts required:
  • Soldered NULA Mini Board
  • Breadboard
  • 1 x Red, Green, Yellow LED
  • 3 x 330Ω resistors
  • 1 x Pushbutton
  • Some jumper wires
Under construction
Required components
Code Example
Import necessary modules.
# Import necessary modules
from machine import Pin, Timer
Define pins used for LEDs.
RED_LED_PIN = 5
YELLOW_LED_PIN = 4
GREEN_LED_PIN = 3
Global variables which control the state of the program flow when a certain action occurs.
request_red = False
green_light_on = False
button_timeout_expired = True
last_button_press = 0
Create a timer by calling Timer() constructor with given id.
timeout_timer = Timer(0)
Pushbutton interrupt handler routine, sets the global request_red variable to True and updates the last_button_press time. This will only be executed if green light is currently ON and timeout for catwalk button has expired.
def irq_handler(pin):
if green_light_on and button_timeout_expired:
global request_red, last_button_press
# Debounce catwalk button
if time.ticks_diff(time.ticks_ms(), last_button_press) >= 500:
last_button_press = time.ticks_ms()
print("Catwalk button pressed!")
request_red = True
Here we define functions to when green light turns off, function green_off_sequence() turns of the green LED after blinking it for few times followed by turning on the yellow LED.
def blink_green():
for _ in range(4):
green_led.value(0)
time.sleep(0.5)
green_led.value(1)
time.sleep(0.5)
def green_off_sequence():
global green_light_on
blink_green()
green_led.value(0)
yellow_led.value(1)
time.sleep(3)
yellow_led.value(0)
Timer handler which triggers 25 seconds after each pushbutton press, during that time catwalk button is disabled to ensure some time between repeated presses.
def timeout_handler(t):
global button_timeout_expired
print("Button timeout expired, can request red light again.")
Define pin for pushbutton and initialize the Pin object. After button initialization attach an interrupt to trigger on press.
BUTTON_PIN = 18
catwalk_button = Pin(BUTTON_PIN, Pin.IN, Pin.PULL_UP)
catwalk_button.irq(trigger=Pin.IRQ_FALLING, handler=irq_handler)
Define and initialize the LEDs and turn them all off initially.
red_led = Pin(RED_LED_PIN, Pin.OUT)
yellow_led = Pin(YELLOW_LED_PIN, Pin.OUT)
green_led = Pin(GREEN_LED_PIN, Pin.OUT)
red_led.value(0)
yellow_led.value(0)
green_led.value(0)
Main loop that starts off by turning on the red LED, followed by yellow and green. Green LED stays on the longest for 10 seconds after which green_off_sequence() begins. While the green LED is on, pushbutton can trigger an interrupt to immediately start the process of turning the green LED off and turning on the red LED.
red_led.value(1) # Turn on red LED
time.sleep(5) # Wait for 10 seconds
yellow_led.value(1) # Turn on yellow LED
time.sleep(3) # Wait for 3 seconds
red_led.value(0) # Turn off red LED
yellow_led.value(0) # Turn off yellow LED
green_led.value(1) # Turn on green LED
# Save the time green light started
green_light_start = time.ticks_ms()
green_light_on = True
# If 10 seconds passed, end green light
if time.ticks_diff(time.ticks_ms(), green_light_start) > 10000:
# Begin green light off sequence and exit the loop
break
# If pushbutton interrupt timeout expired allow the interrupt to happen
if button_timeout_expired:
if request_red == True:
# Reset the flag
request_red = False
button_timeout_expired = False
# Start a 'ONE_SHOT' timer which will trigger only once after 25 seconds
timeout_timer.init(period=25000, mode=Timer.ONE_SHOT, callback=timeout_handler)
break
Full Example
7.1_LED_Traffic_Light.py
