Gnss Gps - Hardware details
Pinout
The pinout image for this board has not been generated yet! We're working on it!
Pin Details
5VPowerSupply voltage.
RXReceive (UART)UART receive pin for communication.
TXTransmit (UART)UART transmit pin for communication.
RST, F-ON, PPS and ANT-D are optional.
RSTResetResets the module when pulled low.
F-ONFunction OnEnables or disables the module’s function.
PPSPulse Per SecondOutputs a timing pulse per second for synchronization.
ANT-DAntenna DataUsed for an external antenna connection.
The PPS pin provides a precise timing signal, useful for advanced applications like time synchronization in high-accuracy systems. If not needed, you can leave it unconnected.
If the built-in antenna doesn't provide a strong enough signal, connect an external antenna via the ANT-D pin for better performance.
The board also features an IPX connector with SMA for an external antenna.
antenna on board
IPX Antenna connector on board
antenna on board
IPX Antenna connector on easyC board
Pin Details (Qwiic version)
GNDDebug GroundGround pin for debugging purposes.
UPDIDebug InterfaceUsed for debugging and programming the onboard ATTiny404 microcontroller.
3V3Debug Power3.3V power supply for debugging purposes.
The GND, UPDI, and 3V3 pins are for debugging and programming purposes only. They are not required for normal operation and should only be used by advanced users.
EasyC/qwiic cable
This board comes in a Qwiic-compatible version! Just plug it into your board using a Qwiic/easyC/STEMMA QT cable and start coding!
Power Consumption
  • Tracking Mode: Consumes approximately 26 mA at 3.3V when actively receiving signals.
  • Acquisition Mode: Uses around 30 mA at 3.3V during initial satellite signal acquisition.
  • Power Saving Modes:
    • AlwaysLocate™ Mode: Dynamically adjusts activity to balance positioning accuracy and power consumption, reducing current usage to ~3.5 mA.
    • Backup Mode: Consumes only 7 µA, preserving system data for quick restarts.
    • Standby Mode: Uses around 1 mA, allowing for faster wake-ups with minimal power draw.
Lower power modes help extend battery life in energy-sensitive applications, making the module ideal for IoT and wearable devices.
Dimensions
  • Board Dimensions: 54mm x 38mm (2.1 x 1.5 inch)
  • Header Pin Holes: 1.5 mm
Jumper Details
This board contains hardware jumpers. See below for their locations and functions:
Loading carousel...
JumperDefault StateFunction
JP1NC (Normally closed)When connected, the voltage regulator is powered by 5V, stepping it down to 3.3V for the IC.
JP2NO (Normally open)When shorted, it bypasses the voltage regulator, allowing the board to be powered directly from 3.3V via headers. Ensure JP1 is disconnected if JP2 is connected.
JP3NC (Normally closed)When closed, enables the PWR LED.
JP4NC (Normally closed)When closed, enables the PPS LED.
Jumper Details (Qwiic version)
Loading carousel...
JP1NC (Normally closed)When closed, enables the PWR LED.
JP2NC (Normally closed)When closed, enables the PPS LED.
Address selection (Qwiic version)
This board contains hardware address switches. See below for how to change the breakout board's address:
Pinout
AddressSW3SW2SW1
0x30000
0x31001
0x32010
0x33011
0x34100
0x35101
0x36110
0x37111
Hardware repository
GNSS GPS L86-M33 breakout hardware design
GNSS GPS L86-M33 breakout with easyC hardware design
The hardware repository contains everything you need to understand, modify, or manufacture the board. The different output folders are versioned. You can check which board version you have by finding the version mark on the PCB.
CAD files
Schematic
BOM (Bill of Materials)
3D files
Gerber files
Compliance
