Lcd I2C - Custom Characters
LCD displays with an HD44780 controller support custom characters, which are stored in CGRAM (Character Generator RAM). These characters are defined using an 8-byte array, where each byte represents a row of a 5x8 pixel grid. By setting the pixels with binary values (1 for on, 0 for off), you can design unique symbols like faces, icons, or symbols.
If you have trouble creating custom characters, you can use a custom character generator.
// Include the library
#include "16x2-LCD-SOLDERED.h"
LCD lcd; // create LCD object
uint8_t happy[8] = {
// happy face
0b00000, 0b10001, 0b00000, 0b00000, 0b10001, 0b01110, 0b00000, 0b00000,
uint8_t wow[8] = {
// wow face
0b00000, 0b10001, 0b00000, 0b01110, 0b10001, 0b01110, 0b00000, 0b00000,
uint8_t anchor[8] = {
// anchor bit array
0b01110, 0b01010, 0b01110, 0b00100, 0b10101, 0b10101, 0b01110, 0b00100};
uint8_t snow[8] = {
// snow bit array
0b01000, 0b11101, 0b01011, 0b00001, 0b00100, 0b01110, 0b00100, 0b10000};
lcd.begin(); // begin the LCD
lcd.backlight(); // turn on the backlight
lcd.createChar(0, happy); // create happy face on char 0
lcd.createChar(1, wow); // create wow face on char 1
lcd.createChar(2, anchor); // create anchor bit array on char 2
lcd.createChar(3, snow); // create snow bit array on char 3
lcd.write(0); // write happy face (char 0)
lcd.write(1); // write wow face (char 1)
lcd.write(2); // write anchor bit array (char 2)
lcd.write(3); // write snow bit array (char 3)
lcd.createChar()
Stores a custom character in the LCD's CGRAM (Character Generator RAM). The 'location' parameter specifies the slot (0-7) where the character will be stored, and 'charmap' is an 8-byte array that defines the pixel pattern of the character.
Returns value: None
uint8_tlocationThe slot (0-7) in the CGRAM where the custom character will be stored.
uint8_t[]charmapAn 8-byte array representing the pixel pattern of the custom character.
tca schematic
LCD Preview
Custom_Chars.ino
Example file for displaying custom characters using the LCD I2C display
