Lcd I2C - Hardware details
Pinout
lcd-i2c pinout diagram
LCD-I2C pinout diagram
Pin Details
5VPowerSupply voltage (5V).
APowerSupply voltage (5V).
CGroundCommon ground for power and signals.
D0-D7DataValues for writing or reading.
EEnableAllows or blocks the flow of data.
R/WRead/WriteSelects reading or writing mode.
RSRegister SelectControls where the data is written.
VODisplay ContrastControls the display contrast.
Qwiic (formerly easyC)
EasyC/qwiic cable
Dimensions
  • Board Dimensions: 54 x 22 mm (2.1 x 0.9 inch)
  • Header Pin Holes: 1.5 mm
  • LCD version:
    • Display dimensions: 64.5 x 16 mm (2.5 x 0.6 inch)
    • Dimensions: 80 x 36 x 12 mm (3.1 x 1.4 x 0.5 inch)
Jumper Details
Loading carousel...
JumperDefault StateFunction
JP2NC (Normally closed)Connects SDA/SCL pull-up resistors to 3.3V for I2C communication.
Address Details
follower address
Three hardware jumpers (A0, A1, and A2) are used to program and vary the fixed I2C follower address and allow up to eight devices to share the same I2C bus or SMBus. The address can be shifted to select a unique address from 0x20 to 0x27.
follower address
Default I2C follower address is 0x20 (0100000).
The default state of all address pins is NO (Normally opened). Closing the pins in different combinations results in different follower addresses. The value of the pin is 0 when opened and 1 when closed (see table below).
A2A1A0Follower Address
0000x20
0010x21
0100x22
0110x23
1000x24
1010x25
1100x26
1110x27
You can run an I2C scanner sketch on your microcontroller to check which address is in use.
LCD Display
The version of the product with the LCD display comes with the HD44780 Dot Matrix Display Driver. It consists of two rows, and each row can print 16 characters (16x2). Each character is built using a 5x8 pixel box, resulting in a total of 1280 pixels.
If you're using our 16x2 I2C LCD Display, make sure you also use our drivers!
lcd display
16x2 LCD module
Hardware repository
LCD-I2C adapter Hardware design
CAD files
Schematic
BOM (Bill of Materials)
3D files
Gerber files
Compliance
