Li Ion Battery - Overview
3.7V Li-Ion Batteries
The Li-Ion Batteries offered are a versatile and reliable power solution for a wide range of electronic projects, including those using Dasduino and Inkplate devices. Equipped with a JST-PH-2mm connector, these batteries ensure easy integration and compatibility with numerous development boards and embedded systems. Each battery features on-board protection, safeguarding against overcharging, over-discharging, and short circuits, making them a safe and durable choice for powering your applications.
Li-ion battery 40mAh 3.7V
Li-ion battery 100mAh 3.7V
Li-ion battery 380mAh 3.7V
Li-ion battery 500mAh 3.7V
Li-ion battery 600mAh 3.7V
Li-ion battery 680mAh 3.7V
Li-ion battery 900mAh 3.7V
Li-ion battery 1200mAh 3.7V
Li-ion battery 1500mAh 3.7V
Li-ion battery 1800mAh 3.7V
Li-ion battery 2100mAh 3.7V
Li-ion battery 3000mAh 3.7V
Li-ion battery 4000mAh 3.7V
Li-ion battery 5000mAh 3.7V
Li-ion battery 6000mAh 3.7V
Li-ion battery 10000mAh 3.7V
Key Features
- Wide Capacity Range: Available in capacities from 40mAh to 10000mAh, catering to both low-power and high-energy applications.
- Standard JST-PH-2mm Connector: Ensures easy integration with devices like Dasduino and Inkplate.
- On-Board Protection: Built-in circuit protection against overcharging, over-discharging, and short circuits, ensuring safety and durability.
- Nominal Voltage: 3.7V
- Compact and Lightweight Design: Ideal for portable and space-constrained projects.
You may also need
Li-ion charger
Li-ion charger for lithium batteries
Li-ion charger with protection
Li-ion charger for lithium batteries with protection
MPPT Li-Ion CN3791 charger board
