Li-ion Charger - Hardware details
Pinout
Li-ion charger pinout
Li-ion Battery Charger pinout diagram
Li-ion Battery Charger with protection pinout diagram
Pin Details
VCCPower InConnect to 5V USB-C power input.
GNDGroundCommon ground.
BAT+Battery +Connect to the positive terminal of a single-cell Li-ion cell.
BAT-Battery -Connect to the negative terminal of the battery.
In addition, the Li-ion Battery Charger with protection board has these pins.
OUT+Output +Regulated output voltage (same as battery voltage).
OUT-Output -Output ground.
These boards are designed for 3.7V Li-ion or Li-Po single-cell batteries.
Dimensions
  • Board Dimensions: 25 × 19 mm (0.98 × 0.75 inch)
  • USB Connector: USB-C female
  • Mounting holes: None (breadboard-compatible)
LEDs
LED NameColorMeaning
CHRGRedCharging in progress
FULLBlueBattery fully charged
Hardware repository
The hardware design files for these modules are available on GitHub:
Li-ion Charger Hardware Repository
Schematics and PCB layout for the charger module
Li-ion Charger with Protection Hardware Repository
The hardware repository contains everything you need to understand, modify, or manufacture the board. The various output folders are versioned. You can check which board version you have specifically by finding the version mark on the PCB.
CAD files
Schematic
BOM (Bill of Materials)
3D files
Gerber files
Compliance
  • Safety Instructions – Safety guidelines and precautions are provided in English and German.
