Li-ion Charger - How it works
The Li-Ion Charger and Li-Ion Charger with Protection are compact modules designed to safely charge single-cell lithium-ion (3.7V nominal) batteries. They incorporate efficient charge management ICs that follow the standard CC/CV (Constant Current / Constant Voltage) algorithm.
Li-Ion Charger
Li-Ion Charger
How Charging Works
1. Constant Current (CC) Phase
When the battery is deeply discharged, the charger supplies a constant current (up to 500mA depending on the module) to the battery while monitoring its voltage. This rapidly charges the battery from 3.0V to approximately 4.2V.
2. Constant Voltage (CV) Phase
Once the battery voltage reaches 4.2V, the charger switches to constant voltage mode. The charging current gradually decreases while maintaining the 4.2V level. Charging ends when the current drops below a preset threshold (usually about 10% of the initial current).
Charging Process Steps
  1. Battery Detection – The IC detects the battery and checks its voltage level.
  2. Preconditioning – If the battery voltage is very low, the charger applies a gentle current to revive it.
  3. CC Phase – The charger delivers full current until approximately 4.2V is reached.
  4. CV Phase – Voltage is held steady while the current drops gradually.
  5. Charge Complete – When the current drops low enough, charging stops, as indicated by the status LED.
The version with protection includes a battery protection circuit, which prevents:
  • Over-discharge – Stops discharging below approximately 2.5V.
  • Overcharge – Cuts off charging above approximately 4.25V.
  • Short circuit – Immediately disconnects the output.
  • Overcurrent – Limits the maximum current draw.
This makes it suitable for standalone battery packs where no additional BMS is used.
TP4056 Charging IC
The TP4056 is a linear charger designed for single-cell lithium-ion batteries. It includes an internal PMOSFET, thermal regulation, and current monitoring.
TP4056 IC
TP4056 Linear Li-ion Charger Controller
Key features:
  • Constant-current / constant-voltage operation
  • 1% charging accuracy
  • Built-in protection for overvoltage and undervoltage
  • LED charge and full indicators
DW01 + FS8205A Protection Circuit
The Li-ion Charger with Protection includes the DW01A battery protection IC and FS8205A dual MOSFET to guard against overcharge, overdischarge, and short circuits.
DW01 + FS8205A
DW01 and FS8205A on protected charger
Additional Protection Features:
  • Overcharge protection at 4.28V
  • Overdischarge cutoff at 2.4V
  • Short-circuit and overcurrent protection
  • Automatically resumes operation when safe
Status LEDs
  • Red LED – Charging
  • Green LED – Charge complete
charging
Red LED - Charging status
Input Power Sources
These modules can be powered from:
  • USB-C port
  • Header pins (5V in)
Make sure the input is at least 5V for proper operation. The output is typically 4.2V max when charging and follows the battery voltage when discharging.
