Lo-Fi Noise Machine - Overview
Introduction
Lo-Fi Noise Machine Kit is a fun, educational electronics project that teaches you the fundamentals of soldering, and at the end you get a really cool sound device! This kit lets you build your own analog noise machine, creating Lo-Fi tones with no digital sound processing or software involved. It features a buzzer, an 8Ω speaker, and a 3.5mm audio jack, giving you the flexibility to choose between three different sound output options depending on how you want to use it.
333349
Contents of the kit
- NE556N dual precision timer
- 2 x potentiometers for controlling pitch and width
- 3.5 mm audio jack
- USB Type C connector
- 0.5W 8Ohm speaker
- Buzzer
- Voltage regulator
- Capacitors:
- 3 x 10nF
- 2 x 100uF
- 1 x 10uF
- 1 x 560uF
- 1 x 100nF
- 1 x 1nF
- 1 x 1uF
- 1 x 220pF
- Resistors:
- 3 x 1k Ohm
- 2 x 2.2k Ohm
- 1 x 10k Ohm
- 1 x 4.7k Ohm
- 1 x 150R 1W
- 1 x 470R
- 1 x 22k Ohm
- 1 x 33k Ohm
- 1 x 0.3R 2W
- 1 x 180R
- 1 x 6.2k
- 2 x LEDs for power & output
- 1 x regular diode
