CAN Transciever MCP2518 - Hardware details
Pinout
Pin Details
| PIn Marking | Pin Name | Description |
| NCS | Chip Select | SPI chip select input |
| SDI | Data input | SPI data input |
| SDO | Data output | SPI data output |
| SCK | Clock input | SPI clock input |
| GND | Ground | Common ground for the module |
| VCC | Supply voltage | Operating voltage input |
| INT1 | Interrupt | RX interrupt output(active low) |
| INT0 | Interrupt | TX interrupt output(active low) |
| INT | Interrupt | Interrupt output (active low) |
| CLKO | Clock output | Clock output/Start of frame output |
Jumper Details
This board contains hardware jumpers See below for their locations and functions:
| JP1 | NO (Normally open) | When closed it adds Termination Resistor |
| JP2 | NC (Normally closed) | Connect/Disconnect PWR LED |
Hardware repository
CAN Transceiver MCP2518 board Hardware Design
Hardware design, BOM, gerbers and 3D files for CAN-Transceiver-MCP2518-board designed by Soldered Electronics.
The hardware repository contains everything you need to understand, modify, or manufacture the board. The different output folders are versioned. You can check which board version you have by finding the version mark on the PCB.
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
