Hardware details
Pinout
Pin Details
| VBAT | Power | Battery input for 3.7 V Li-Ion/Li-Poly battery through the JST connector. |
| VCC | Power | Main power input (5 V via USB-C or external 5 V supply). |
| 3V3 | Power | Regulated 3.3 V output from the onboard regulator. |
| RESET | Control | Hardware reset pin. |
| IO0–IO48 | GPIO | General-purpose I/O pins, supporting PWM, I²C, SPI, UART, ADC, and touch. |
| RX | RX | UART0 receive pin for serial communication. |
| TX | TX | UART0 transmit pin for serial communication. |
Qwiic / easyC Connector
Learn more about Qwiic hardware compatibility and connector pinout.
Power Supply and Battery
- USB-C Port is used for both programming and powering the board
- VBAT (JST connector) is used for connecting a 3.7 V Li-Ion or Li-Poly battery
- The board includes an integrated Li-Ion charge management circuit
- Operating voltage: 3.3 V (onboard regulator for 5 V input via USB-C)
For 5 V input, always power the board through the USB-C port.
Power Consumption
| Mode | Typical Current |
| Active (Wi-Fi TX) | around 240 mA |
| Modem-sleep | around 20 mA |
| Light-sleep | around 1.5 mA |
| Deep-sleep | around 7 µA |
Achieving the lowest deep-sleep current
The NULA DeepSleep ESP32-S3 has been engineered to minimize power consumption during sleep modes, making it ideal for long-term battery-powered applications such as remote sensors and data loggers.
When properly configured, the board can achieve a deep-sleep current as low as 7 µA, consistent with the values specified in the ESP32-S3 datasheet.
This level of performance assumes that all peripheral components are powered down and that the RGB status LED (WS2812B) is electrically isolated.
To achieve the lowest possible consumption:
- Ensure that no external devices are drawing power from the 3V3 or VCC rails during sleep.
- Disconnect any I²C sensors or modules that lack dedicated power management.
- Open the JP1 solder jumper to physically disconnect the onboard WS2812B RGB LED, which can otherwise introduce a small but measurable leakage current.
Dimensions
- Board size: 69 × 26 mm (2.72 × 1.02 inch)
- Mounting: Breadboard compatible
- Header Pin Holes: 1.5 mm
Soldered boards are LEGO compatible! 🧱
Jumper Details
This board includes one hardware jumper that can be modified to optimize power usage.
| JP1 | NC (Normally closed) | Disconnects the WS2812B RGB LED to minimize standby current in deep-sleep mode. |
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
