Hardware details
Pinout
Pin Details
| VBAT | Power | Battery input for 3.7 V Li-Ion/Li-Poly battery through the JST connector. |
| VCC | Power | Main power input (5 V via USB-C or external 5 V supply). |
| 3V3 | Power | Regulated 3.3 V output from the onboard regulator. |
| IO2 | GPIO | General-purpose I/O pin, supports PWM. |
| IO3 | GPIO | General-purpose I/O pin, SPI MOSI function available. |
| IO4 | GPIO | General-purpose I/O pin, SPI MISO function available. |
| IO5 | GPIO | General-purpose I/O pin, SPI SCK function available. |
| IO18 | GPIO | General-purpose I/O pin, supports PWM. |
| IO19 | GPIO | General-purpose I/O pin, supports PWM. |
| TX | TX | UART0 transmit pin used for serial communication. |
| RX | RX | UART0 receive pin used for serial communication. |
Breadboard mounting recommendation
When using the NULA Mini ESP32-C6 on a breadboard, we recommend soldering male header pins so that the ESP32-C6 module (chip) faces downwards toward the breadboard.
This orientation keeps the board level and stable because the JST battery connector on the opposite side is taller and can prevent a flat fit on the breadboard.
This provides better mechanical stability and makes the USB-C port easier to access.
Qwiic / easyC Connector
Learn more about Qwiic hardware compatibility and connector pinout.
Power Supply and Battery
- USB-C Port is used for both programming and powering the board
- VBAT (JST connector) is used for connecting a 3.7 V Li-Ion or Li-Poly battery
- The board includes an integrated Li-Ion charge management circuit
- Operating voltage: 3.3 V (onboard regulator for 5 V input)
For 5 V input, always power the board through the USB-C port.
Power Consumption
| Mode | Typical Current |
| Active (Wi-Fi TX) | around 120 mA |
| Modem-sleep | around 25 mA |
| Light-sleep | around 1 mA |
| Deep-sleep | around 7 µA |
Dimensions
- Board size: 25.33 × 25.33 x 10.0 mm (1.00 x 1.00 x 0.39 inch)
- Mounting: Breadboard compatible
- Header Pin Holes: 1.5 mm
Soldered boards are LEGO compatible! 🧱
Jumper Details
This board includes two hardware jumpers that can be modified to adjust behavior or reduce power consumption.
| JP1 | NC (Normally closed) | Disconnects the Power LED to reduce standby current draw when running from battery power. |
| JP2 | NC (Normally closed) | Connects the 3.3 V I²C pull-up resistors for SDA and SCL lines when required by connected I²C devices. |
Use JP2 when connecting I²C sensors or peripherals that do not include onboard pull-up resistors.
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
