Overview
Introduction
Make your own Dasduino is an educational electronics kit that teaches you how to solder, with which you end up with a functional microcontroller board. It is based on the ATmega328P microcontroller, and all SMD components are already soldered on the board. The set also includes a THT socket for the microcontroller, which simplifies the replacement of the microcontroller should it ever become necessary.
What does it do
When this kit is fully assembled, it functions as any ATmega328P-based microcontroler board.
Make yout own Dasduino
Contents of the kit
  • PCB
  • 7 capacitors of 100nF
  • 4 capacitors of 2.2uF
  • 2 capacitors of 22pF
  • 5 2.2kOhm resistors
  • 5 10-kOhm resistors
  • 3 1-kOhm resistors
  • 1 100-kOhm resistors
  • 1 100-ohm resistors
  • 1 JST battery connctor
  • 5 LEDs (purple, white, ble, red, orange, one of each)
  • Socket for ATmega328P
  • ATmega328P MCU
