Stepper Motor Driver - Hardware details
Pinout
Pinout
Click here for a high reoslution image of the pinout.
Pin details
IN1Stepper Coil A1First terminal of Coil A in the stepper motor.
IN2Stepper Coil A2Second terminal of Coil A in the stepper motor.
IN3Stepper Coil B1First terminal of Coil B in the stepper motor.
IN4Stepper Coil B2Second terminal of Coil B in the stepper motor.
GNDSignal Ground (Microcontroller)Ground reference for the control signals from the microcontroller.
VCCMotor Supply Voltage (+)Positive DC voltage input for the stepper motor power supply.
GNDMotor Ground (-)Ground connection for the stepper motor power supply.
The IN pins can work at 3V3 or 5V logic
14V is the maximum supported Motor supply voltage!
If you have the version of this product with the stepper motor, the motor supply voltage needs to be exactly 5V!
As for the actual stepper motor connection, this is the pinout of the connector, in relation to the input pins:
Basic stepper driver connected to Dasduino CORE
Jumper Details
This board contains hardware jumpers, see below for their locations and functions:
Loading carousel...
JumperDefault StateFunction
JP1NC (Normally closed)Enables the power indicator LED, which indicates when power is supplied to the stepper motor.
JP2NO (Normally open)When shorted, it enables the output LEDs that pulse for each pin.
Dimensions
  • Board Dimensions: 38 × 22 mm (1.5 × 0.9 inch)
  • Header Pin Holes: 1.5 mm
Motor
The version of the product with the stepper motor ships with the 28BYJ-48 5V DC stepper motor. It's cable fits the connector on our basic stepper board and can just be plugged in. This motor has 2048 steps per one revolution. See below for a pinout in relation to the internal coils:
Hardware repository
Basic stepper driver Hardware design
CAD files
Schematic
BOM (Bill of Materials)
3D files
Gerber files
Compliance
