2.4" TFT LCD Breakout with Touch - Reading Raw Touch Data
This example helps you understand how to read raw X, Y coordinates and pressure values from the touchscreen controller on the 2.4" TFT LCD breakout.
It’s useful for diagnosing touch issues or performing touchscreen calibration.
TouchScreenRaw.ino
This example only reads touch values – it does not render anything on the screen.
#include "SPI.h"
#include "TFT-LCD-Breakout-2.4-With-Touch-SOLDERED.h"
TFTTouch ts(5); // Replace with the correct CST pin
ts.begin();
ts.service(); // Refresh touch status
if (ts.getPressure()) {
Serial.print("X: ");
Serial.print(ts.getX());
Serial.print(" | Y: ");
Serial.print(ts.getY());
Serial.print(" | Pressure: ");
Serial.println(ts.getPressure());
delay(100); // Small delay to avoid flooding serial monitor
Output Format
When you touch the display, you’ll see a stream like this in your Serial Monitor:
X: 714 | Y: 412 | Pressure: 315
X: 718 | Y: 417 | Pressure: 310
Use Case
Use this sketch to determine the minimum and maximum raw values for both X and Y axes. These values are essential for proper touchscreen calibration with the calibrate() function.
ts.calibrate(x_max, x_min, y_max, y_min);
Full Example
TouchScreenRaw.ino
Example sketch to read raw X, Y, and pressure values from the TFT touchscreen.
