2.4" TFT LCD Breakout with Touch – Hardware Details
Pinout
The pinout image for this board hasn't been generated yet! We're working on it!
Pin Details
Pin MarkingFunctionDescription
VCCPowerConnect to 3.3V or 5V depending on board's onboard level shifting
GNDGroundCommon ground connection
CLKSPI Clock (SCK)Clock signal for display and touchscreen
DISPI Data (MOSI)Data output from MCU to display
D0SPI Data (MISO)Data input from touchscreen (optional for touch)
CSLDisplay Chip SelectChip Select for TFT ILI9341 driver
DCData/Command SelectControl signal for distinguishing commands from data
RSTResetOptional hardware reset
CSTTouch Chip SelectChip Select for touch controller (XPT2046)
BLBacklightConnect to VCC or PWM-capable GPIO for brightness control
Dimensions
  • Board size: 70 x 54 mm
  • Screen size: 2.4"
  • Resolution: 240 × 320 pixels
  • Touch Panel Type: Resistive (XPT2046)
  • Backlight: Edge-lit LED
What is TFT?
TFT stands for Thin-Film Transistor, a display technology that provides active matrix control over each pixel using dedicated transistors. This ensures:
  • Faster refresh rates
  • Higher brightness and contrast
  • Better responsiveness compared to passive matrix LCDs
Components on Board
  • ILI9341: Main TFT display controller (SPI)
  • XPT2046: Resistive touchscreen controller (SPI)
  • microSD socket: SPI interface for data logging, image display, etc.
  • Level-shifter circuitry: Ensures compatibility with 3.3V and 5V logic
Typical Wiring to Microcontroller
MCU PinConnects ToNotes
SPI MOSIDIData to display
SPI MISOD0Needed for reading touch data
SPI SCKCLKClock line
GPIO (Digital)CSLChip Select for TFT
GPIO (Digital)CSTChip Select for Touch
GPIO (Digital)DCData/Command
GPIO (PWM)BLOptional for brightness control
VCCVCC3.3V or 5V depending on board
GNDGNDGround
Notes
Make sure your board supplies adequate current. Display with backlight may consume up to 100mA under full brightness and load.
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
3D files
Gerber files
Compliance
