Voice to Web
Stream live microphone audio to your browser
This example sets up an ESP32 as a Wi-Fi Access Point with a tiny web page that plays the SPK0641HT4H-1 microphone stream in real time over WebSockets.
WebSockets library is recommended for this example. You can download it through Arduino Library Manager tab.
#include <WiFi.h>
#include <WebServer.h>
#include <WebSocketsServer.h>
#include "Soldered-Microphone-SPK0641HT.h"
const char* ssid = "RP2350_Audio_Stream";
const char* password = "123456789";
WebServer server(80);
WebSocketsServer webSocket(81);
const int SAMPLE_RATE = 16000;
const int CHANNELS = 1;
const int BIT_DEPTH = 16;
const int SAMPLES_PER_BUFFER = 160;
const int BYTES_PER_BUFFER = SAMPLES_PER_BUFFER * 2;
uint8_t audioBuffer1[BYTES_PER_BUFFER];
uint8_t audioBuffer2[BYTES_PER_BUFFER];
uint8_t* currentBuffer = audioBuffer1;
uint8_t* sendBuffer = audioBuffer2;
int bufferIndex = 0;
bool bufferReady = false;
unsigned long lastAudioSend = 0;
const int AUDIO_SEND_INTERVAL = 10;
Microphone mic;
int clientCount = 0;
void handleRoot() {
String ip = WiFi.softAPIP().toString();
String html = R"html(
<!DOCTYPE html><html><head><meta charset="utf-8"/><title>Audio Stream</title>
<style>body{font-family:system-ui;margin:24px}button{padding:10px 16px;font-size:16px}</style>
</head><body>
<h1>ESP32 Live Microphone Audio</h1>
<button id="btn">Start</button>
<div id="status">Disconnected</div>
<script>
let ac, ws, jb=[], playing=false;
document.getElementById('btn').onclick = () => {
if(playing) return;
ac = new (window.AudioContext||window.webkitAudioContext)({sampleRate:16000});
ws = new WebSocket('ws://)html";
html += ip;
html += R"html(:81); ws.binaryType='arraybuffer';
ws.onopen=()=>{document.getElementById('status').textContent='Connected'; start();}
ws.onclose=()=>{document.getElementById('status').textContent='Disconnected';}
ws.onmessage=e=>{ if(e.data instanceof ArrayBuffer){ jb.push(new Int16Array(e.data)); } }
function start(){
const bs=256; const sp=ac.createScriptProcessor(bs,1,1);
let cur=null, pos=0; playing=true;
sp.onaudioprocess=e=>{
const out=e.outputBuffer.getChannelData(0);
for(let i=0;i<bs;i++){
if(cur && pos<cur.length){ out[i]=cur[pos++]/32768.0; }
else { cur = jb.length? jb.shift(): null; pos=0; out[i]=0; }
sp.connect(ac.destination);
</script></body></html>
)html";
server.send(200, "text/html", html);
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
if (type == WStype_CONNECTED) clientCount++;
else if (type == WStype_DISCONNECTED) clientCount--;
void readMicData() {
if (bufferReady) return;
int16_t samples[SAMPLES_PER_BUFFER];
int n = mic.read(samples, SAMPLES_PER_BUFFER);
if (n > 0) {
for (int i=0;i<n;i++) {
if (bufferIndex*2+1 < BYTES_PER_BUFFER) {
currentBuffer[bufferIndex*2] = samples[i] & 0xFF;
currentBuffer[bufferIndex*2+1] = (samples[i] >> 8) & 0xFF;
bufferIndex++;
if (bufferIndex >= SAMPLES_PER_BUFFER) { bufferReady = true; bufferIndex = 0; }
void handleAudioStreaming() {
unsigned long now = millis();
if (clientCount > 0 && bufferReady && (now - lastAudioSend >= AUDIO_SEND_INTERVAL)) {
uint8_t* tmp = sendBuffer; sendBuffer = currentBuffer; currentBuffer = tmp;
webSocket.broadcastBIN(sendBuffer, BYTES_PER_BUFFER);
bufferReady = false; lastAudioSend = now;
WiFi.softAP(ssid, password);
server.on("/", handleRoot);
server.begin();
webSocket.begin();
webSocket.onEvent(webSocketEvent);
const int PDM_CLK = 4;
const int PDM_DIN = 27;
mic.begin(PDM_DIN, PDM_CLK, SAMPLE_RATE, BIT_DEPTH, SAMPLES_PER_BUFFER);
mic.setHPF(true);
mic.setGainDb(10.0f);
server.handleClient();
webSocket.loop();
readMicData();
handleAudioStreaming();
mic.begin(int pinData, int pinClk, uint32_t sampleRate, uint16_t bitDepth, size_t samplesPerBuffer)
Initializes the microphone driver and PDM capture on ESP32 with the chosen pins and audio parameters.
Returns value: bool, true on success
mic.setHPF(bool enabled)
Enables a high-pass filter to reduce DC and very low-frequency components.
Returns value: None
mic.setGainDb(float gainDb)
Applies digital post-decimation gain (dB).
Returns value: None
mic.read(int16_t* dst, size_t samples)
Reads up to 'samples' PCM16 values from the capture buffer.
Returns value: int, number of samples read
Connection example.
Expected output.
voiceToWAV_ESP32.ino
Record microphone audio to WAV on ESP32
