LSM6DS – Measuring temperature with LSM6DS3 (example)
This page contains some simple examples with function documentation on how to measure temperature using the LSM6DS Accelerometer & Gyroscope sensor.
Initialization
To start working with the Temperature Sensor in LSM6DS 6-DOF Breakout, you need to set up your Arduino environment. First, include the required library, create the sensor object, and initialize the sensor in the setup() function. You can use the return of begin() to check if everything is connected correctly:
// Include libraries
#include "LSM6DS3-SOLDERED.h"
#include "Wire.h"
// Create an LSM6DS3 object
Soldered_LSM6DS3 myIMU; // Default address is 0x6B
delay(1000);
// Initialize sensor
if (!myIMU.begin())
// 'begin' returned false, there is an error
Serial.println("Can't initialize LSM6DS3!");
Serial.println("Check connection!");
while (true)
Serial.println("LSM6DS3 initialized successfully.");
myIMU.begin()
Initializes the **LSM6DS3 Accelerometer & Gyroscope sensor**, setting up communication over I2C or SPI and configuring the sensor for operation. This function also verifies the presence of the sensor on the specified I2C address or SPI bus.
Returns value: **Returns `true`**: If initialization is successful, indicating that the sensor is properly connected and configured. - **Returns `false`**: If initialization fails, indicating a connection issue or incorrect configuration.
To start measuring temperature data, you can use the following functions to read values in Celsius and Fahrenheit and display them as shown below:
// Read the temperature and print it on serial
Serial.print("DEGC:");
Serial.print(myIMU.readTempC(), 4);
Serial.print(",");
Serial.print("DEGF:");
Serial.println(myIMU.readTempF(), 4);
myIMU.readTemp*()
Reads the temperature value from the LSM6DS3 sensor in Celsius (`readTempC`) or Fahrenheit (`readTempF`).
Returns value: Returns a floating-point number representing the temperature in degrees Celsius or Fahrenheit.
Try all of the above-mentioned functions in this full example, which prints out the measured temperature data over Serial at 115200 baud:
#include "Wire.h"
// Create object from LSM library
// Init serial communication
delay(1000); // Relax...
// Call .begin() to configure the IMU
myIMU.begin();
// Get all parameters and print it on the Serial Monitor
Serial.print(",");
delay(150);
minimalistExample.ino
Most basic example of use. Example using the LSM6DS3 with basic settings
