LSM6DS – Getting started
Arduino library
To install the Arduino library, you can use the Arduino library manager or download it from the GitHub repository (all 3 variants use the same library):
Accelerometer & Gyroscope LSM6DS 6-DOF breakout Arduino library
Soldered-LSM6DS3-Arduino-Library
First time Arduino user? For a detailed tutorial on how to get started wtih Arduino, see this section of our docs:
Getting started with Arduino
Connections
QwiicQwiic
If you prefer, you can use I2C pins to manually connect:
IO21 (Default SDA pin)SDA
IO22 (Default SCL pin)SCL
VCCVCC
GNDGND
The IO21 and IO22 pins can differ for your personally used board, so make sure to validate the information before you start working!
