LSM6DS – Hardware details
Pinout
Pin details
| VCC | Power | Supply voltage (both 5V and 3V3 are supported). |
| SDA | Data | I2C data line for communication. |
| SCL | Clock | I2C clock line for communication. |
| INT1 | Interrupt | Programmable interrupt 1. |
| INT2 | Interrupt | Programmable interrupt 2. |
Qwiic (formerly easyC)
Power consumption
The LSM6DS3 is designed for low-power operation, making it ideal for IoT and battery-powered applications.
| Mode | Current Consumption |
| Normal mode | ~0.9 mA |
| High-performance mode | ~1.6 mA |
Dimensions
- Board Dimensions: 2.5 mm × 3 mm × 0.83 mm (0.09 × 0.11 × 0.03 inch)
- Header Pin Holes: 1.5 mm
- Soldered boards are LEGO-compatible! 🧱
Jumper Details
| JP1 | NC (Normally closed) | Connects SDA/SCL pull-up resistors to 5V for I2C communication. |
| JP2 | NC | Connects SDA/SCL pull-up resistors to 3.3V for I2C communication. |
| JP3 | NC | When connected, the voltage regulator is powered by 5V, stepping it down to 3.3V for the IC. |
| JP4 | NO (Normally open) | When shorted, it bypasses the voltage regulator, allowing the board to be powered directly from 3.3V via headers. Ensure JP3 is disconnected if JP4 is connected. |
| JP5 | NO | Address jumper (More below) that allows swapping between two addresses. |
Address jumper
As mentioned above, the JP5 is an address jumper that, when left open, has the address 0x6B, while when closed its address changes to 0x6A.
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
