Apds-9960 – Hardware details
Pinout
APDS-9960 pinout diagram
Pin Details
VLEDPowerSupply current for IR LED.
INTControlInterrupt signal (from APDS-9960).
This breakout board operates at 3.3V logic level, but includes an onboard regulator for 5V compatibility, so it can be connected to both 3V3 and 5V logic boards!
Qwiic (formerly easyC)
EasyC/qwiic cable
Power Consumption
  • Sleep mode: Uses just 1.0 µA, making it ideal for low-power applications.
  • Active mode: Depends on the functions in use. Uses up to 100mA.
For best results, consider utilizing sleep mode during inactivity and fine-tuning the IR LED timing for your specific needs.
Window Air Gap
Skip this section if using the sensor in open air.
Crosstalk is the output caused by unwanted reflection of LED IR rays, even in the absence of any object. To control this interference when the sensor is used in gesture mode, we recommend fitting a rubber isolating barrier over the sensor.
APDS-9960 Barrier design
The rubber consists of two cylindrical openings, one for the LED and the other for the Photodetector. When assembled, the rubber barrier should form a good optical seal to the bottom of the window.
Air GapPD Opening DiameterLED Opening Diameter
1mm2mm1.5mm
Dimensions
  • Board Dimensions: 38 × 22 mm (1.5 × 0.9 inch)
  • Header Pin Holes: 1.5 mm
Jumper Details
Loading carousel...
JumperDefault StateFunction
JP2NC (Normally closed)Connects SDA/SCL pull-up resistors to 3.3V for I2C communication.
JP3NC (Normally closed)Disconnect to remove VLED power supply.
JP4NC (Normally closed)When connected, the voltage regulator is powered by 5V, stepping it down to 3.3V for the IC.
JP5NO (Normally open)When shorted, it bypasses the voltage regulator, allowing the board to be powered directly from 3.3V via headers. Ensure JP4 is disconnected if JP5 is connected.
Hardware repository
APDS-9960 Hardware design
CAD files
Schematic
BOM (Bill of Materials)
3D files
Gerber files
Compliance
