Battery Protection - Hardware details
Pinout
bp pinout diagram
1S Li-Ion Battery Protection pinout diagram
Pin Details
GNDGroundCommon ground for the battery circuit.
VBATBatteryMain voltage input from the battery (positive terminal).
BAT-NegativeBattery negative terminal (connected to the negative pole).
BAT+PositiveBattery positive terminal (connected to the positive pole).
Ensure that GND is connected to both the high and low voltage grounds to establish a common reference for signals.
Do not short the BAT+ and BAT- pins. Short-circuiting these pins can cause overheating, damage to the protection circuit, or battery failure.
FS8205A MOSFET
The FS8205A is a dual N-channel MOSFET commonly used in battery protection circuits for efficient switching and low power loss.
bp pinout diagram
FS8205A MOSFET on the Battery Protection Board
The FS8205A has a low on-resistance of 25mΩ (max) at V_GS = 4.5V, ensuring minimal power dissipation during operation. It also has a drain-source voltage rating of 20V, making it suitable for typical lithium battery voltage levels. With a continuous drain current of 6A, it provides sufficient current handling for most battery protection applications. The MOSFET is packaged in an SOT-23-6, a compact, space-efficient surface-mount package.
In battery protection systems, the FS8205A is used in both the charge and discharge paths. It ensures safe operation by preventing overcurrent and short-circuit conditions, thereby protecting the battery and associated circuits.
The FS8205A operates within a junction temperature range of -55°C to 150°C, making it suitable for a wide range of operating conditions. Its gate threshold voltage is around 1V, which allows for efficient switching with low gate drive voltages and contributes to the system’s overall energy efficiency.
Dimensions
  • Header Pin Holes: 1.5 mm
Jumper Details
jp1
JP1
JumperDefault StateFunction
JP1NC (Normally closed)Connects PWR LED.
Hardware repository
1S Li-Ion Battery Protection Hardware Design
The hardware repository contains everything you need to understand, modify, or manufacture the board. The various output folders are versioned. You can check which board version you have specifically by finding the version mark on the PCB.
CAD files
Schematic
BOM (Bill of Materials)
3D files
Gerber files
Compliance
  • Safety Instructions – Safety guidelines and precautions are provided in English and German.
