Hardware details
Pinout
[IMAGE PLACEHOLDER - BMP280 pinout]
Pin Details
| VCC | Power | Supply voltage (both 5V and 3V3 are supported). |
| SDA | Data | I2C data line for communication. |
| SCL | Clock | I2C clock line for communication. |
Qwiic (formerly easyC)
Dimensions
- Board Dimensions: 22 × 38 mm (0.9 × 1.5 inch)
- Header Pin Holes: 1.5 mm
- Soldered boards are LEGO compatible! 🧱
Jumper Details
[JUMPER DETAILS PLACEHOLDER]
| JP1 | NC (Normally closed) | Connects SDA/SCL pull-up resistors to 5V for I2C communication. |
| JP2 | NO (Normally open) | When shorted, it changes the last address bit from 0 to 1 effectively changing devices I2C address from 0x76 to 0x77. |
| JP3 | NC (Normally closed) | Connects SDA/SCL pull-up resistors to 3.3V for I2C communication. |
| JP4 | NC (Normally closed) | When connected, the voltage regulator is powered by 5V, stepping it down to 3.3V for the I2C. |
| JP5 | NO (Normally open) | When shorted, it bypassess the voltage regulator, allowing the board to be powered directly from 3.3V via headers. Ensure JP4 is disconnected if JP5 is connected. |
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
