How it works
BMP280 is an integrated circuit by Bosch. When using our board, you are essentially communicationg with the onboard BMP280 directly via I2C communication.
BMP280 sensor
Onboard BMP280 sensor
Datasheet
For an in-depth look at tehnical specifications, refer to the official BMP280 Datasheet:
BMP280 Datasheet
Detailed technical documentation for the BMP280 sensor
How the sensor works
The BMP280 is a pressure and temperature sensor that can also calculate altitude based on pressure. The sensor takes measurements by using the piezoresistive effect to gather information.
The piezoresistive effect is a change in the electrical resistivity of a material (e.g., semiconductor, metal) when mechanical strain is applied. The electrical resistance change is due to two causes: a change in geometry and a change in conductivity of the material. The change in resistance is much more pronounced for semicnductors than for metals.
Four Si-resistors are diffused into a semiconductor membrane and connected together to form a Wheatstone bridge. Under the influence of pressure, the diaphragm deforms, thereby affecting the electrical resistance of the foru Si-resistors. The change in resistance is proportional to the applied pressure.
Piezoresistor schema
Schematic diagram of the pressure sensor, originally from article [Temperature Compensation Method for Piezoresistive Pressure Sensors Based on Gated Recurrent Unit](https://www.mdpi.com/1424-8220/24/16/5394)
I2C communication
The BMP280 uses the I2C protocol to communicate with a microcontroller. It operates with a default I2C address of 0x76 (alternatively 0x77 by shorting JP2) and supports a speed of up to 3.4MHz for rapid data transmission.
Upon request, the sensor responds with pressure values in a 16 to 19 bit format and temperature values in a 16 bit format.
