Breadboard Power - Overview
Breadboard power supply
The Breadboard power supply is a simple and stable power source for your breadboard projects. Supply it with power via the DC jack or with a USB-C cable, and the board provides 3.3V, 5V, or 12V directly to the power supply lines on the breadboard. Output voltages are adjustable separately using the onboard switches. It also includes a power LED, a power switch, and an automatic voltage selection circuit in case both power inputs are connected.
Breadboard power supply board
333084
Key Features
- Input: USB-C or DC jack
- Voltage on DC jack: 12V DC
- Voltage on USB-C: 5V
- Output current: 3V3 @ 500mA, 5V @ 1A
- Dimensions: 54 x 30mm (2.1 x 1.2 inches)
You may also need
Power supply 12V 2A 24W
108769
