Capacitive Soil Sensor - How to Use
This page provides basic usage instructions for the Capacitive Soil Sensor, including how to connect it to your microcontroller (e.g., Dasduino Connect Plus), and how to write a simple sketch to start reading soil moisture levels.
How to Connect
The sensor has three pins:
| Pin | Function | Description |
| VCC | Power | Connect to 3.3V or 5V on your board. |
| GND | Ground | Connect to the ground of your board. |
| AOUT | Analog Output | Connect to an analog-capable GPIO pin on your board. |
Always use a pin capable of analog input (ADC). On ESP32-based boards like Dasduino Connect Plus, we recommend using GPIO 32 or 33.
Recommended Pins for ESP32
Use ADC1 channels to avoid Wi-Fi interference. Below are the safe pins for analog input:
| GPIO | ADC Channel | Notes |
| 32 | ADC1_CH4 | Recommended |
| 33 | ADC1_CH5 | Recommended |
| 34 | ADC1_CH6 | Input only (safe) |
| 35 | ADC1_CH7 | Input only (safe) |
| 36 | ADC1_CH0 | Input only (safe) |
| 39 | ADC1_CH3 | Input only (safe) |
Avoid using ADC2 pins when Wi-Fi is active, as it causes conflicts and unreliable readings.
Example Code
Here’s a simple sketch to read analog soil data using a safe ADC1 pin:
const int sensorPin = 33; // Use a safe ADC1 pin like GPIO 32 or 33
int sensorValue = analogRead(sensorPin);
Serial.print("Soil Moisture Reading: ");
Serial.println(sensorValue);
delay(1000);
analogRead(pin)
Reads the analog voltage on the specified pin and returns a value from 0 to 4095 on ESP32 boards.
Returns value: Returns an integer analog value between 0 (dry) and 4095 (wet).
| Type | Name | Description |
int | pin | The GPIO number connected to the sensor’s analog output. |
Calibration Tip
You may wish to record the minimum and maximum values observed for your specific soil and water conditions, and map them into a percentage:
int value = analogRead(sensorPin);
int percentage = map(value, 1200, 3200, 0, 100); // Adjust based on your readings
percentage = constrain(percentage, 0, 100);
Serial.print("Soil Moisture: ");
Serial.print(percentage);
Serial.println("%");
Next Steps
- Try logging the data to an SD card or over Wi-Fi.
- Create alerts or automatic watering based on moisture thresholds.
- Integrate the sensor into a full smart gardening project!
