Electrochemical Gas Sensors – Calibrating a sensor
In this example we will go over calibrating the internal zero voltage value of the sensor.
Depending on the humidity and temperature, a sensor calibration may be needed. Calibrating should be done in a vacuum or area where there is no trace of the gas we want to measure.
First, in the Electrochemical-Gas-Sensor-SOLDERED.h header file, uncomment the following define macro:
// This define will cause debug messages to print in our library
// Useful when calibrating the sensor
#define ELECTROCHEMICAL_SENSOR_DEBUG //UNCOMMENT THIS
Next, we have to include the library, create an instance of the sensor object and define the internal zero calibration value we will use to calibrate the sensor:
// Include the required library
#include "Electrochemical-Gas-Sensor-SOLDERED.h"
// This is the custom value we set for the calibration voltage
// This value is added to the voltage read from the ADC
// In an environment with 0 of the target gas, the voltage after calibration should be
// roughly 0, adjust customCalibration to get it to that value.
const double customCalibration = 0.05;
// Create the sensor object with the according type
ElectrochemicalGasSensor sensor(SENSOR_NH3, 0x49, 32);
Next, in the setup() function, we are initializing the sensor and setting the custom calibration value right after:
Serial.begin(115200); // For debugging
// Initialize the breakout
if (!sensor.begin())
// Can't init? Notify the user and go to infinite loop
Serial.println("ERROR: Can't init the sensor! Check connections!");
while (true)
delay(100);
//Set the custom calibration value
sensor.setCustomZeroCalibration(customCalibration);
Serial.println("Sensor initialized successfully!");
sensor.setCustomZeroCalibration(double calibration)
Sets the internal zero calibration offset
Returns value: None
doublecalibrationInternal zero calibration offset in volts
Finally, with the debug functions we can see the raw voltage, voltage without and with the calibration value:
// Make the reading
double reading = sensor.getPPM();
// This function will also print debug messages if the #define in
// the header file of the library is uncommented
// It will print:
// - The raw voltage measurement
// - Voltage without reference value
// - Voltage after calibration
// These values can help you adjust the internal zero calibration
// Print the reading with 5 digits of precision
Serial.print("Sensor reading: ");
Serial.print(reading, 5);
Serial.println(" PPM");
// Wait a bit before reading again
delay(2500);
Serial monitor
Serial monitor
See the full example in the link below:
Calibration example
Calibration example for electrochemical sensors
