Electrochemical Gas Sensors – Custom configuration example
In different environments, a custom configuration may need to be created. We will cover it in this example.
First, include the library and create the custom configuration. Each attribute is defined below:
// Include the required library
#include "Electrochemical-Gas-Sensor-SOLDERED.h"
* Here are parameters to configure for the custom sensor:
* nanoAmperesPerPPM: From the datasheet of the particular electrochemical
* sensor, used in the calculation of PPM/PPB
* internalZeroCalibration: A fixed value that is added to the voltage
* measured by the ADS. The value here should make the reading be
* just barely 0 PPM when the sensor is in a place with none of the target gas
* adsGain: The gain of the ADS
* The voltage here represents the maximum range it can measure
* ADS_GAIN_6_144V 6.144 V
* ADS_GAIN_4_096V 4.096 V
* ADS_GAIN_2_048V 2.048 V
* ADS_GAIN_1_024V 1.024 V
* ADS_GAIN_0_512V 0.512 V
* ADS_GAIN_0_256V 0.256 V
* TIA_GAIN_IN_KOHMS: The gain of the amplifier
* This increases the sensitivity of the measurement
* TIA_GAIN_EXTERNAL External resistance
* TIA_GAIN_2_75_KOHM 2.75 kOhm
* TIA_GAIN_3_5_KOHM 3.5 kOhm
* TIA_GAIN_7_KOHM 7 kOhm
* TIA_GAIN_14_KOHM 14 kOhm
* TIA_GAIN_35_KOHM 35 kOhm
* TIA_GAIN_120_KOHM 120 kOhm
* TIA_GAIN_350_KOHM 350 kOhm
* RLOAD: The load resistor in the LMP91000
* Specified in the electrochemical sensor's datasheet
* RLOAD_10_OHM 10 Ohm
* RLOAD_33_OHM 33 Ohm
* RLOAD_50_OHM 50 Ohm
* RLOAD_100_OHM 100 Ohm
* REF_SOURCE: Source of the control voltage reference
* For our breakout, use external; there is a 2.5V external
* reference voltage
* REF_INTERNAL Internal
* REF_EXTERNAL External
* INTERNAL_ZERO: Internal zero selection
* If the electrochemical sensor has a positive polarity, you
* would usually want to use 20% for the most headroom in the signal
* INTERNAL_ZERO_20_PERCENT 20%
* INTERNAL_ZERO_50_PERCENT 50%
* INTERNAL_ZERO_67_PERCENT 67%
* INTERNAL_ZERO_BYPASSED Internal zero bypassed
* BIAS_SIGN: The polarity of the bias voltage
* BIAS_SIGN_NEGATIVE Negative
* BIAS_SIGN_POSITIVE Positive
* BIAS: Added bias, percentage of the reference voltage
* Most sensors don't require this; check each sensor's datasheet
* BIAS_0_PERCENT 0%
* BIAS_1_PERCENT 1%
* BIAS_2_PERCENT 2%
* BIAS_4_PERCENT 4%
* BIAS_6_PERCENT 6%
* BIAS_22_PERCENT 22%
* BIAS_24_PERCENT 24%
* FET_SHORT: Short the FET
* Used to preserve the electrochemical sensor
* It must be disabled for the sensor to be operable
* FET_SHORT_DISABLED Disabled
* FET_SHORT_ENABLED Enabled
* OP_MODE: Mode of operation
* OP_MODE_DEEP_SLEEP Deep Sleep (default)
* OP_MODE_2LEAD_GROUND_CELL 2-lead ground referred galvanic cell
* OP_MODE_STANDBY Standby
* OP_MODE_3LEAD_AMP_CELL 3-lead amperometric cell
* OP_MODE_TEMPERATURE_TIA_OFF Temperature measurement (TIA Off)
* OP_MODE_TEMPERATURE_TIA_ON Temperature measurement (TIA On)
* For more details, check the LMP91000 datasheet, chapter 7.6
// Here is an example of a custom configuration:
const sensorType SENSOR_CUSTOM = {
100.0F, // nanoAmperesPerPPM
0, // internalZeroCalibration
ADS_GAIN_4_096V, // adsGain
TIA_GAIN_120_KOHM, // TIA_GAIN_IN_KOHMS
RLOAD_10_OHM, // RLOAD
REF_EXTERNAL, // REF_SOURCE
INTERNAL_ZERO_20_PERCENT, // INTERNAL_ZERO
BIAS_SIGN_NEGATIVE, // BIAS_SIGN
BIAS_0_PERCENT, // BIAS
FET_SHORT_DISABLED, // FET_SHORT
OP_MODE_3LEAD_AMP_CELL, // OP_MODE
// Create the sensor object with the custom type
ElectrochemicalGasSensor sensor(SENSOR_CUSTOM);
The rest of the sketch follows the same structure as the previous example:
Serial.begin(115200); // For debugging
// Init the breakout
if (!sensor.begin())
// Can't initialize? Notify the user and go to an infinite loop
Serial.println("ERROR: Can't init the sensor! Check connections!");
while (true)
delay(100);
Serial.println("Sensor initialized successfully!");
// Take a reading
double reading = sensor.getPPM();
// Print the reading with 5 digits of precision
Serial.println("Sensor reading: ");
Serial.print(reading, 5);
Serial.println(" PPM");
// Wait a bit before reading again
delay(2500);
Serial monitor
sensor.begin()
Initializes the LMP91000 and ADS1115 on the board and establishes an I2C connection
Returns value: Boolean value; returns true if successful, false if it fails
sensor.getPPM()
Makes a measurement with the ADS1115 ADC and calculates the PPM value of the measured gas
Returns value: Double value; gas measurement in PPM (parts per million)
See the full example here:
Custom configuration example for electrochemical sensors
