Electrochemical Gas Sensors – Reading from multiple sensors
In this example, we demonstrate how to read from multiple sensors over I2C.
First, include the library and create the sensor objects by providing the configuration, the I2C address of the ADS1115, and the GPIO pin connected to the LMPEN pin on the breakout board:
// Include the required library
#include "Electrochemical-Gas-Sensor-SOLDERED.h"
// Create two different sensor objects
// Through the constructor, give them the configuration,
// ADC I2C address and GPIO pin connected to the LMPEN pin
ElectrochemicalGasSensor sensorCO(SENSOR_CO, 0x4A, 25);
ElectrochemicalGasSensor sensorNO2(SENSOR_NO2, 0x49, 32);
We can change the I2C address of the ADS1115 ADC module by shorting jumpers on the breakout board. For more information on the jumpers look here
While the LMP91000 has a non-configurable I2C address, we can distinguish them by setting the LMPEN pin. When we want to configure a specific one, we can disable all the others by setting their LMPEN pin to HIGH via the GPIO pins while the one we want to configure stays at a HIGH state. More information about this can be found here
Next, in the setup() function, both sensors are initialized, along with the serial communication:
Serial.begin(115200); // For debugging
// Init breakout #1
if (!sensorCO.begin())
// Can't init? Notify the user and go to infinite loop
Serial.println("ERROR: Can't init the sensor! Check connections!");
while (true)
delay(100);
Serial.println("CO sensor initialized successfully!");
// Init breakout #2
if (!sensorNO2.begin())
while (true)
delay(100);
Serial.println("NO2 sensor initialized successfully!");
sensor.begin()
Initializes the LMP91000 and ADS1115 on the board and establishes an I2C connection
Returns value: Boolean value, returns true if it was successful, false if it failed
Getting readings
Finally, in the loop() function, we print the gas readings to the serial monitor:
// Make the reading of CO and print it
double COreading = sensorCO.getPPM();
// Print the reading with 5 digits of precision
Serial.print("CO sensor reading: ");
Serial.print(COreading, 5);
Serial.println(" PPM");
// Make the reading of NO2 and print it
double NO2reading = sensorNO2.getPPB();
Serial.print("NO2 sensor reading: ");
Serial.print(NO2reading, 5);
Serial.println(" PPB");
// Wait a bit before reading again
delay(2500);
sensorCO.getPPM()
Make a measurement with the ADS1115 ADC and calculate the PPM value of the measured gas
Returns value: Double value, gas measurement in PPM (parts per million)
sensorNO2.getPPB()
Make a measurement with the ADS1115 ADC and calculate the PPB value of the measured gas
Returns value: Double value, gas measurement in PPB (parts per billion)
See the full example here:
Measuring two sensors
Example of getting measurements from two sensors
// Init breakout #1
while (true)
delay(100);
// Init breakout #2
while (true)
delay(100);
delay(2500);
