Electrochemical Gas Sensors – Single sensor measurement example
Connections for this example
When using a single sensor, make sure to connect the LMPEN pin to the GND pin on the board. This ensures that the pin is set to LOW and that the LMP91000 is always enabled. For more information, look here.
Initializing the sensor
To initialize the sensor, we must first include the library and create an instance of the sensor object with a configuration for the appropriate type (for this example, we are using an ammonia sensor). You can find all of the pre-defined configurations here.
// Include the library
#include "Electrochemical-Gas-Sensor-SOLDERED.h"
// Create the sensor object with the according type
ElectrochemicalGasSensor sensor(SENSOR_NH3);
Next, in the setup() function, we initialize the serial communication as well as the breakout board itself:
// Initialize the breakout
if (!sensor.begin())
// Can't initialize? Notify the user and enter an infinite loop
Serial.println("ERROR: Can't init the sensor! Check connections!");
while (true)
delay(100);
Serial.println("Sensor initialized successfully!");
sensor.begin()
Initializes the LMP91000 and ADS1115 on the board and establishes an I2C connection
Returns value: Boolean value, returns true if it was successful, false if it failed
Taking a measurement
Finally, in the loop() function, we get the reading from the breakout board and print it to serial:
// Make the reading
double reading = sensor.getPPM();
// Print the reading with 5 digits of precision
Serial.print("Sensor reading: ");
Serial.print(reading, 5);
Serial.println(" PPM");
// Wait a bit before reading again
delay(2500);
Serial monitor
Serial monitor
sensor.getPPM()
Makes a measurement with the ADS1115 ADC and calculates the PPM value of the measured gas
Returns value: Double value, gas measurement in PPM (parts per million)
sensor.getPPB()
Make a measurement with the ADS1115 ADC and calculate the PPB value of the measured gas
Returns value: Double value, gas measurement in PPB (parts per billion)
See the full example here:
// Include the required library
Serial.begin(115200); // For debugging
while (true)
delay(100);
// Make the reading
delay(2500);
