Electrochemical Gas Sensors – Hardware details
Pinout
Pin details
| VCC | Power | Supply voltage (both 5V and 3V3 are supported). |
| SDA | Data | I2C data line for communication. |
| SCL | Clock | I2C clock line for communication. |
| AIN1 | Analog input | Analog input 1 |
| AIN2 | Analog input | Analog input 2 |
| AIN3 | Analog input | Analog input 3 |
| VOUT | Analog output | Analog output from LMP |
| ALERT | Digital output | High when the conversion data exceeds the Hi_thresh register or falls below the Lo_thresh register value. |
| LMPEN | LMP enable | Module Enable, Active-Low |
Qwiic (formerly easyC)
Dimensions
- Board Dimensions: 38 × 38 mm (1.5 × 1.5 inch)
- Header Pin Holes: 1.5 mm
- Soldered boards are LEGO compatible! 🧱
LMPEN pin functionality
The LMP91000 comes with a unique and fixed I2C address of 0x48. It is still possible to connect more than one LMP91000 to an I2C bus and select each device using the LMPEN pin. The LMPEN simply enables or disables the I2C communication of the LMP91000. When the LMPEN is at a logic level low, all I2C communication is enabled; conversely, when the LMPEN is at a high logic level, I2C communication is disabled. In a system based on a microcontroller with more than one LMP91000 connected to the I2C bus, the I2C lines (SDA and SCL) are shared, while the LMPEN of each LMP91000 is connected to a dedicated GPIO port of the microcontroller. The microcontroller starts communication by asserting one out of N LMPEN signals, where N is the total number of LMP91000s connected to the I2C bus. Only the enabled device will acknowledge the I2C commands. After finishing communication with this particular LMP91000, the microcontroller de-asserts the corresponding LMPEN and repeats the procedure for the other LMP91000s.
Sensor datasheets
| SKU | Sensor name | Datasheet |
| 333325 | SGX-4SO2 - Sulphur Dioxide sensor | Datasheet |
| 333326 | SGX-4NO2 - Nitrogen Dioxide sensor | Datasheet |
| 333327 | SGX-4NO-250 - Nitric Oxide sensor | Datasheet |
| 333328 | SGX-4CO - Carbon Monoxide sensor | Datasheet |
| 333329 | SGX-403-20 - Ozone sensor | Datasheet |
| 333330 | SGX-4NH3-300 - Ammonia sensor | Datasheet |
| 333331 | SGX-4H2S-100 - Hydrogen Sulphide sensor | Datasheet |
| 333332 | SGX-4CL2 - Chlorine sensor | Datasheet |
Jumper Details
This board contains hardware jumpers. See below for their locations and functions:
| JP1 | NC (Normally closed) | Connects SDA/SCL pull-up resistors to 5V for I2C communication. |
| JP2 | NC (Normally closed) | Connects SDA/SCL pull-up resistors to 3.3V for I2C communication. |
| JP3 | NC (Normally closed) | When connected, the voltage regulator is powered by 5V, stepping it down to 3.3V for the IC. |
| JP4 | NO (Normally open) | When shorted, it bypasses the voltage regulator, allowing the board to be powered directly from 3.3V via headers. Ensure JP3 is disconnected if JP4 is connected. |
| JP5 | NC (Normally closed) | When shorted, it sets the I2C address to 0x49. |
| JP6 | NO (Normally open) | When shorted, it sets the I2C address to 0x4A. |
| JP7 | NO (Normally open) | When shorted, it sets the I2C address to 0x4B. |
Hardware repository
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
- Safety Instructions – Safety guidelines and precautions in both English and German.
