Gnss Gps - Getting started
Arduino library
GNSS GPS L86-M33 board Arduino library
GNSS L860-M33 Arduino library by Soldered
Getting started with Arduino
Connections
QwiicQwiic
If you're using the regular version, use these pins to manually connect:
Dasduino CONNECTPLUSL86-M33 Board
VCC5V
GNDGND
IO22 (any digital pin)TX
IO21 (any digital pin)RX
For the optional pins:
RESETRST
IO18 (any digital pin)F-ON
IO19 (any digital pin)PPS
Antenna connectorANT-D
