Hall Effect Sensor - Detecting magnetic presence with Qwiic digital sensor
This page contains a simple example with function documentation on how to take measurements using the SI7211-B-06-IV Hall effect sensor and Qwiic connection.
Qwiic Digital output example
#include "Hall-Effect-SOLDERED.h"
HallEffect_Digital_EasyC hall;
// Initialize sensor via EasyC (required!)
hall.begin();
// Read sensor
bool hallReading = hall.getReading();
// Print sensor value to serial
Serial.print("Digital Hall Effect Sensor reading: ");
Serial.println(hallReading);
// Print a string depending on the measurement result
if(hallReading)
Serial.println("Magnet detected!\n");
else
Serial.println("No magnet detected.\n");
// Wait a bit until next measurement
delay(1000);
HallEffect_Digital_EasyC hall()
Creates digital sensor object
Returns value: none
hall.begin()
Initialises digital sensor object
Returns value: Returns true if initialization is successful, false otherwise.
uint16_taddressOptional, used for changing breakout address, default is 0x30
hall.getReading()
Requests a new reading from the SI7211-B-00-IV sensor.
Returns value: Returns bool value, true if magnet is detected and false for no magnet detected.
Sensor when magnet is not present
Serial Monitor output
Sensor when magnet is present
Try all of the above mentioned functions in this full example which detects presence of magnetic object.
digitalReadEasyC.ino
Example file for using Digital Hall effect sensor with easyC/Qwiic/I2C
