Hall Effect Sensor - Measuring strength of magnetic field with regular analog
This page contains a simple example with function documentation on how to take measurements using the SI7211-B-00-IV Hall effect sensor.
Analog output example
#include "Hall-Effect-SOLDERED.h"
#define HALL_EFFECT_PIN 12
// To change the reading, place a magnet in front of the sensor
// The sensor outputs a value approximately in the middle of your analogRead range
// A higher number indicates a stronger positive magnetic force
// A lower number indicates a stronger negative magnetic force
HallEffect_Analog hall(HALL_EFFECT_PIN);
// Read sensor and store to variable
uint16_t hallReading = hall.getReading();
float hallMilliTeslas = hall.getMilliTeslas();
// Print sensor values to serial
Serial.print("Analog Hall Effect raw sensor reading: ");
Serial.println(hallReading);
Serial.print("Analog Hall Effect sensor reading in milli Teslas: ");
Serial.print(hallMilliTeslas);
Serial.println(" mT\n");
// Wait a bit until next measurement
delay(1000);
HallEffect_Analog hall()
Creates analog sensor object
uint16_tpinAnalog pin number for data communication
hall.getReading()
Requests a new reading from the SI7211-B-00-IV sensor.
Returns value: Returns int value from output pin
Calculates the value of magnetic induction from current reading
Returns value: Returns float value that represents magnetic induction in milli Teslas
Sensor when magnet is not present
Serial Monitor output
Sensor when magnet is present
Try all of the above mentioned functions in this full example which measures the strenght of magnetic field.
analogRead.ino
Example file for using analog Hall effect sensor
