Hall Effect Sensor - Hardware details
Pinout
Pin details for regular version with digital output
| VCC | Power | Supply voltage (both 5V and 3V3 are supported). |
| OUT | Data | Data line for digital communication. |
Pin details for regular version with analog output
| OUT | Data | Data line for analog communication. |
Pin details for Qwiic version
For Qwiic version, connection is achieved with Qwiic connector.
Qwiic (formerly easyC)
Dimensions
- Board Dimensions: 22 × 22 mm (0.9 × 0.9 inch)
- Header Pin Holes: 1.5 mm
- Soldered boards are LEGO compatible! 🧱
Address selection for Qwiic version
This board contains hardware address switches, see below how to change the breakout board's address.
| Address | SW3 | SW2 | SW1 |
| 0x30 | 0 | 0 | 0 |
| 0x31 | 0 | 0 | 1 |
| 0x32 | 0 | 1 | 0 |
| 0x33 | 0 | 1 | 1 |
| 0x34 | 1 | 0 | 0 |
| 0x35 | 1 | 0 | 1 |
| 0x36 | 1 | 1 | 0 |
| 0x37 | 1 | 1 | 1 |
Hardware repository
Hall effect sensor breakout with digital output hardware design
Hardware design, BOM, gerbers and 3D files for Hall-effect-sensor-breakout-with-digital-output designed by Soldered Electronics.
Hall effect sensor breakout with analog output hardware design
Hardware design, BOM, gerbers and 3D files for Hall-effect-sensor-breakout-with-analog-output designed by Soldered Electronics.
Hall effect sensor breakout with digital output---qwiic hardware design
Hardware design, BOM, gerbers and 3D files for Hall-effect-sensor-breakout-with-digital-output-&-qwiic designed by Soldered Electronics.
Hall effect sensor breakout with analog output---qwiic hardware design
Hardware design, BOM, gerbers and 3D files for Hall-effect-sensor-breakout-with-analog-output-&-qwiic designed by Soldered Electronics.
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
