Hc Sr04 – Hardware details
Pinout
Pin details
| VCC | Power | Supply voltage (5V) |
| ECHO | Echo | Pin that receives the reflected wave |
| TRIG | Trigger | Pin that emits the start pulse |
| 3V3 | Power | Supply voltage for the UPDI |
| UPDI | UPDI | Communication pin for UPDI |
Qwiic (formerly easyC)
Dimensions
- Board Dimensions: 45 x 22 mm (1.8 x 0.9 inch)
Address selection (Qwiic version)
This board contains hardware address switches. See below for instructions on changing the breakout board's address:
| Address | SW3 | SW2 | SW1 |
| 0x30 | 0 | 0 | 0 |
| 0x31 | 0 | 0 | 1 |
| 0x32 | 0 | 1 | 0 |
| 0x33 | 0 | 1 | 1 |
| 0x34 | 1 | 0 | 0 |
| 0x35 | 1 | 0 | 1 |
| 0x36 | 1 | 1 | 0 |
| 0x37 | 1 | 1 | 1 |
Hardware repository
Ultrasonic sensor with easyC Hardware design
The hardware repository contains everything you need to understand, modify, or manufacture the board. The different output folders are versioned. You can determine your board version by checking the version mark on the PCB.
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
