Ltr 507 - Reading Light and Proximity
This page contains simple examples with function documentation on how to use the LTR-507 sensor to read ambient light levels and proximity.
Reading Light
// Include needed libraries
#include "LTR-507-Light-And-Proximity-Sensor-SOLDERED.h"
// Create light_sensor object
LTR507 light_sensor;
// Begin Serial for debugging purposes
// Initialize the light_sensor!
light_sensor.init();
// Create a local variable for the light reading
uint16_t lightReading;
// Obtain the reading!
lightReading = light_sensor.getLightIntensity();
// Print the reading
Serial.print("Light sensor reading: ");
Serial.println(lightReading);
// Wait a bit before taking the next reading so that the output isn't too fast
delay(1000);
Reads the ambient light intensity in lux from the LTR-507 sensor.
Returns value: A 16-bit integer (lux).
The higher the lux value, the brighter the environment. A lower lux value means a darker setting. This can be useful for automatic brightness adjustment, environment monitoring, and smart lighting applications.
Sensor with a connected IR LED in open air
Serial Monitor output
Sensor covered by a hand
LTR-507 Light Sensor Serial Monitor output
readLight.ino
Example file for reading the light sensor value using the LTR-507
Reading Proximity
The LTR-507 measures the infrared reflection from nearby objects to determine their proximity. This is useful for gesture detection, object detection, and automatic triggering systems.
An IR LED must be connected!
// Include the library
LTR507 light_sensor; // Create light_sensor object
Serial.begin(115200); // Initialize Serial Monitor
light_sensor.init(); // Initialize the light_sensor
uint16_t proximityReading = light_sensor.getProximity(); // Read proximity value
Serial.print("Proximity reading: ");
Serial.println(proximityReading); // Print proximity value to Serial Monitor
delay(1000); // Wait before the next reading
Reads the proximity value based on infrared reflection from nearby objects.
Returns value: A 16-bit integer.
readProximity.ino
Example file for reading the proximity sensor value using the LTR-507
