Ltr 507 – Hardware details
Pinout
Pin details
| VCC | Power | Supply voltage (both 5V and 3V3 are supported). |
| SDA | Data | I2C data line for communication. |
| SCL | Clock | I2C clock line for communication. |
| VLED | Power | Current supply for the proximity LED. |
| INT | Control | Interrupt signal (from LTR-507). |
Qwiic (formerly easyC)
Power Consumption
The LTR-507ALS-01 sensor is designed for low power consumption, making it suitable for battery-powered applications.
- Low-power mode: 0.2mA
- Active mode: 2.3 mA
Dimensions
- Board Dimensions: 38 × 22 mm (1.5 × 0.9 inch)
- Header Pin Holes: 1.5 mm
- Soldered boards are LEGO compatible! 🧱
Jumper Details
This board contains hardware jumpers. See below for their locations and functions:
| JP1 | NC (Normally closed) | Connects the SDA/SCL pull-up resistors to 5V for I2C communication. |
| JP2 | NC (Normally closed) | Connects the SDA/SCL pull-up resistors to 3.3V for I2C communication. |
| JP3 | NC (Normally closed) | Address selection (default I2C address 0x3A). |
| JP4 | NC (Normally closed) | When connected, the voltage regulator is powered by 5V, which steps it down to 3.3V for the IC. |
| JP5 | NO (Normally open) | When shorted, it bypasses the voltage regulator, allowing the board to be powered directly from 3.3V via headers. Ensure that JP4 is disconnected if JP5 is connected. |
Address Selection
The LTR-507 sensor has a configurable 7-bit I2C address, determined by the state of the SEL pin. Depending on how the pin is connected, the sensor will respond to one of three possible addresses:
| SEL Pin State | I2C Address |
| GND (0) | 0x23 |
| VCC (1) | 0x26 |
| Floating | 0x3A |
If your I2C scanner detects address 0x3A, this means the SEL pin is floating (not connected to either GND or VCC).
Hardware repository
Digital light & proximity sensor LTR-507 breakout Hardware Design
CAD files
Schematic
BOM (Bill of Materials)
- A standard
3D files
Gerber files
- Copper layers (
Compliance
- Safety Instructions – Safety guidelines and precautions in both English and German.
