Ltr 507 - Overview
LTR-507
The LTR-507 Breakout board offers precise ambient light (ALS) and proximity (PS) measurements, transmitting data via I2C communication for easy integration with microcontrollers such as Dasduino. The device supports an interrupt feature that eliminates the need to poll the sensor for a reading, thereby improving system efficiency.
LTR-507 Light and Proximity Sensor
333063
- Proximity Detection: Detects objects within a range of up to 20cm
- Ambient Light Measurement: Measures light levels from 0 to 65535 lux
- Communication: I2C (400kHz)
- I2C Address: 0x3A
- Logic / Operating voltage level: 3.3V (onboard regulator for 5V compatibility)
- Compatibility: Arduino, and other I2C-compatible microcontrollers
- Operating Temperature Range: -40°C to +85°C
- Mounting: Four mounting holes for secure attachment
- Dimensions: 38 x 22 mm (1.5 x 0.9 inch)
You may also need
Qwiic cable
5mm IR LED
Infra-red (IR) diode that emits light in the spectrum which the human eye can’t see.
