Mcp23017 - Overview
MCP23017 IO Expander
The MCP23017 IO expander allows you to connect an additional sixteen digital inputs/outputs. It also has two interrupt pins! It is simple to use since it communicates via I2C communication with a hardware-defined address of 0x27 (which can be changed via jumpers on the board) and is designed for seamless Qwiic (formerly easyC) connectivity.
IO expander MCP23017 breakout
333007
Key Features
- Standard current consumption: 1 mA
- Standby current consumption: 1 µA
- Logic voltage level: 5V
- Operating voltage level: 1.8V - 5.5V
- Communication: I2C (address: 0x27)
- Connectors: Qwiic x2
- Mounting holes: 2
- Dimensions: 38 x 22 mm (1.5 x 0.9 inch)
You may also need
Qwiic cable
